Since I am no longer making the centerstands for the RSV, there have been some requests for the measurements of the bracket. Here is one that I quickly through together to get the measurements from. Not that the large holes on the U bracket and the straight bar are 16 mm. The ground out part at the bottom of the bar is so that the stand breaks over the proper amount. This varies per stand. I always put them together and then grind it out until the stand breaks JUST over verticle. Too much and it is hard to get the bike off the stand.
Thanks, I'll look into it.
And thanks for the specs on these parts.
I think there are a bunch of people out there that appreciate you makeing these parts for so long!! I know I do!!
I have a Freebird Center Stand.
Had it on for 3 days. I took it off. It scraped the same time the mufflers did when I turned.
I'd sell it for 85 shipped.
  • 4 months later...
About the only way would be to replace the straight bars and not grind them down quiet as much. Would be easy to do though.
Don, Do you have a couple of the straight bars left that I could buy from you at MX day?
Or even a piece of the stock so I could make 2 new ones. The bars are ground out just a little too much for mine. It is almost impossible for me to get it back off of the stand.
Thanks, and I understand if you are too busy for one more thing before the mob gets there, it's no problem. I can find some stock here, but if you happened to have some just laying there in the way--
