Jimod Posted January 14, 2008 #1 Posted January 14, 2008 I've removed the instrument cluster and can't get the face off until I remove the Illumination control. Anyone know how to remove the control ? Does it just pull off or what ???? Jim O'D..
Neil86 Posted January 14, 2008 #2 Posted January 14, 2008 There is a small philips screw in the center of the knob that must be removed Jim, then the knob pulls off.
Condor Posted January 14, 2008 #3 Posted January 14, 2008 There is a small philips screw in the center of the knob that must be removed Jim, then the knob pulls off. Thanks Neil. That's a great tid bit of information. I've posed this question several years ago and didn't get any responses. The problem was I couldn't see good enough to figure out what...or if anything... was down inside that hole in the knob. I had a hard time finding a phillips that would fit, and I have a lot of them. What I did find that would fit was a small slotted screwdriver with a tapered tip. With it I could get a bite on something, and unscrewed what ever is in there?? When I finally did get the screw out it was as you said. I small phillips with a lot of dirt packed in the cross hatch..
Neil86 Posted January 14, 2008 #4 Posted January 14, 2008 I find having a set of those small screwdriver kits for electronics from Radio Shack is handy.
Condor Posted January 14, 2008 #5 Posted January 14, 2008 I find having a set of those small screwdriver kits for electronics from Radio Shack is handy. I've got 'm laying all over the place, but never in the right size when I need it.....
sleepy2 Posted January 16, 2008 #6 Posted January 16, 2008 Thanks Jimod for posting this question and thanks Neil86 for the answer. I too have the panel off to change speedo and thought there might be a screw but couldn't see or feel what kind.
