There are a lot of differences between an 83 & an 84, but most everything is interchangable. Let us know what you want to replace and it'd be better to go from there.
Maybe rear caliper, if can't loosen mine
rear rotor, if in good shape
carbs, just for a spare
seat, if in better shape than mine
maybe even repaint some plastic, if in better shape than mine
exhaust, if in better ..........
not sure yet what else
http://novascotia.kijiji.ca/c-cars-vehicles-motorcycles-touring-2-for-1-1983-YAMAHA-VENTURE-REDUCED-W0QQAdIdZ374867023
Really looking to purchase this bike, and do not need it all. Will be looking to part out most of it. Just wondering how much 83' parts are in need? Also, mine is an 84, so can someone tell me how much of this I can use on it? How interchangeable are the parts from 83 to 84? Thanks
Outside of a few subtle changes it's all interchangable. Dash and choke lever are two items that come to mind that aren't the same but can still be 'adapted'.... If you're thinking about selling off parts the market might not be the best for 1stGen stuff lately.... When shipping the stuff to the US the cost will kill any sales south....
Be kind of picky. If both bikes were stored inside, it's a good deal. if they are back yard forgotten parts bikes, even $500.00 may be too much.
Everything you've listed will be identical, except the sidecovers (if that's the plastic you are thinking of). Now the side panels will work, except you will also have to change the frame braces (they unbolt---easy to change). THe lower sidepanel mount on the 83 has uses a grommet on the frame brace, and the 84 and later uses a rubber piece to latch the lower side of the side panels.
Frank
Frank
True, but only the first 300 or so Ventures in '83 had the gromet, not all '83's. Yamaha went to the strap very quickly due to the plastic 'horns' breaking. My '83 was #389 and had the straps..
Yah! Carbs will not be a direct replacement due to where they take the vacuum from for ignition advance. The '83 is 180 degrees out of phase with the rest of them...
