Its funny. I go around to Napa, Autozone, and O'Rieley AutoParts... and no one has the K&N HP1005... 1004 and 1006, but NOT 1005, SPECIAL ORDER.
Lovely, none the less Amazon has come thru, for 11.92, its coming this Saturday (Prime shipping) so this Saturday, I'll be doing a oil change, oil filter swap, spark plug swap, and maybe if I man up. A check of my diaphragms; I'll go with just... doing the on bike carb cleaner trick.
Its mostly a lot of hope, the sliders, and diaphragms, I can't do anything with if they're busted, and I'm guessing the sliders are fine--the bike starts, and go its whole tank just fine--but the sliders are injured... and noticable scaring was evident on them when we had the carbs off for checkage during the whole three month snafu, and actually don't slide as GRACEFULLY as they should... so new sliders, new diaphragms hopefully next month, or the month after. Though I will point out, the diaphragms were actually FINE then. So hmmm. :scratchchin: Though anyone got any info if I could use OTHER slides than the ones that come with the diaphragms on Ebay (VMAX slides)? some sliders are shiny metal........
So thats the plan..... now all I need to do is fine a nice size rubbermaid bowl for top ramen with sliced sausage this saturday while I work.
but none the less... WHY IS THE K&N HP1005 A SPECIAL ORDER?!?!?!?!?! :soapbox:
Oooh, should I stick with the NGK spark plugs, the DPR8EA-9 NGK is what I got in my memopad for spark plugs (and X24EPR-U9?) Oil if anyone asks, was thinking of 15w40, 50/50 blend from our local motorcycle dealer.
--And if anyone wonders, K&N HP1005 is the screw on oil filter that fits on the Rivco Screw on Oil Filter Adapter. Took me a hour to find that... I think I use a jump from a NAPA number... or was it FRAM? :scratchchin:
Edited by JohnMidnight
Here is the list I had on the filters to fit the Rivco adaptor.
Oil Filter (Gold) FIL 1381
Product Line: NAPA Filters
Interchange Mfg.: Fram (Autolite)
Interchange Mfg. Part Number: PH3950
Oil Filter (NASCAR) NFI 91381
Product Line: NASCAR Select Filters
Oil Filter - Mobil One MFI M1105
Product Line: Mobil One Filters
Oil Filter (ProSelect) SFI 21381
Product Line: NAPA ProSelect Filters
Oil Filter - K&N Filters BK 7355554
Product Line: Balkamp
Interchange Mfg. Part Number: PH3950 BK 7355554 '
Mike
