GolfVenture Posted June 6, 2012 #1 Posted June 6, 2012 What actually is Vapor Lock? Are there something one can do to miminize vapor lock occuring.
Snaggletooth Posted June 6, 2012 #3 Posted June 6, 2012 Basically liquid fuel over heated until it become vapor, boils up like steam. You lose a good share of the needed combustability due to lack of fluid fuel. Alcohol based fuels are a major cause of it from my experience.
hog Posted June 6, 2012 #4 Posted June 6, 2012 Basically liquid fuel over heated until it become vapor, boils up like steam. You lose a good share of the needed combustability due to lack of fluid fuel. Alcohol based fuels are a major cause of it from my experience. In hot weather I would not run ethanol gas in it ,plus it also happens more frequently after filling up tank because of the gas being cool from being underground in tanks.I heard a trick but never tried it and it was to put a wooden clothes pin on the fuel line.Don't know if it works or not.
raybear71 Posted June 6, 2012 #5 Posted June 6, 2012 Back in my drag racing days I used a Moroso cool can. Basically a small cooler with a copper fuel line coiled inside, add water and ice to cool the fuel before it reaches the engine.
KIC Posted June 6, 2012 #6 Posted June 6, 2012 With hot Arizona temperatures, My KLR650 would overheat the gas tank if I left the tank bag on it. Several times it got so hot that the gad would actually boil in the tank. I had never seen that happen before, but if the vent isn't venting correctly and the gas gets hot enough, it will build pressure and boil. Boiling gas in a tank is really interesting to see. Also, if your gas is ever boiling...be VERY careful about opening up the gas cap. Mine had so much pressure in it that when I opened it, it "blew" out through the filler neck all over the hot bike. I have never had that problem so far with any other bikes in Arizona.
Snaggletooth Posted June 6, 2012 #7 Posted June 6, 2012 Back in my drag racing days I used a Moroso cool can. Basically a small cooler with a copper fuel line coiled inside, add water and ice to cool the fuel before it reaches the engine. Some Kids had all the fancy toys! When were were hitting the drag strip we had a coffee can with a coil of copper tubing inside spliced into the fuel line. Fill the thing up with ice and off we went. Cheap! yep. And effective.
