I've read some old posts about this subject but wonder if there is something newer I've missed. To use my brake pedal, I have to raise my foot up off the footboard which does not provide much control of the brake pressure being applied. This is because the pedal is too far back. I'd like to be able to keep my heel on the board and the only solution I see is to lengthen the pedal three or four inches.
Anyone out there have a different solution?
OH yeah well I just read a few posts from guys with the same issue on Gen2's so...so...so there! Ha...told you didn't I..........
You could dismount the Pedal from the Axle and relocate it at a lower Position. Just don't go too low, and check if the Master has a little Freeplay when the Pedal is not in use.
  • 4 weeks later...
