My speedo and rpm gauge lenses are hazy and there is a crack in the rpm gauge. Is there a way to replace the clear plastic lenses without replacing the whole gauge unit?
i would assume that effort wise, you'd be better just to replace the whole unit, if you could get ahold of one. If anything, break em out, that'll solve two problems :{P
Well, here was my thought. I can have some clear plastic discs made to match the original lenses from the local plastics business. Then, using a side cutting dremel blade, carefully cut the original lens out and adjust the cut out with a half round file. Glue them in with some type of clear glue. I do have a spare unit to practice on.
From what I found on line it looks like all the lenses are the same from 83 to 86. I'm sure your method will be less expensive but if you're looking for a stock alternative....
http://m.yamaha-motor.com/PartsViewer.aspx#/Yamaha/XVZ12TK_-_1983/METER/XVZ12TK_(1983_MOTORCYCLE)/METER_(XVZ12TK_-_1983)
http://www.powersportsplus.com/parts/detail/yamaha/YP-26H-8353G-00-00.html
I have also seen a couple on ebay but I didn't have any luck searching by the Yamaha part #.
Hope this helps. :080402gudl_prv:
Brian
