Flyinfool Posted May 31, 2012 #1 Posted May 31, 2012 Since it will be wet and the ground possibly soft. I will bring a supply of polished Stainless steel pads to put under your side stand (a pair also works well under the center stand) so we do not have to pick up to many bikes that might want to take a nap in the nice soft wet grass. It will be first come first serve.
Yammer Dan Posted May 31, 2012 #2 Posted May 31, 2012 That would be nice Jeff. I was looking for something this morning.
M61A1MECH Posted May 31, 2012 #3 Posted May 31, 2012 Jeff Do you drill a hole in those for a lanyard? I have a plastic pab I use for hot asphalt parking lots. Has astring on it, I keep it in mt tank mounted pouch, that way I can get iit out and lower it into position with out getting off the bike and with the string tied onto the left grip I am unlikely to ride off and leave it on the parking lot.
Flyinfool Posted May 31, 2012 Author #4 Posted May 31, 2012 You may drill a hole it you want. If you can. These are not being made for this, It is a piece of scrap that I rescue from the scrap man. It is the punch out for a hole of that shape that we need on one of the products we make where I work. there is no way I could talk them into adding a punch to the die to add a hole in a piece of scrap.
