Depends on the trailer, size of tire and other things.
I have a small trailer, about 150lbs empty, for that I run about 15 lbs each side. If I going to put more in it than the bike should pull, I might put 20 lbs in it. Criteria is that you should have as much tire on the road as possible, but not have it soft on the bottom so that it runs hot.
While I still don't have a "formula"...you have helped immensely...I do realize the error of my ways! I wore a trailer tire out on my trip to MO and IL...had 25 lbs in it and the tread went wieder-bye-bye!
