LtShame Posted May 30, 2012 #1 Posted May 30, 2012 HID kit arrived..going in for the install...wish me luck..lol
Flyinfool Posted May 30, 2012 #2 Posted May 30, 2012 Good Luck!!! Don't forget to add an on off switch while you are in there.
djh3 Posted May 30, 2012 #3 Posted May 30, 2012 Yea that. Its a heck of a lot easier to do the first time around. Some good suggestions on how to do it were in another thread. One had a way to do it with a quasa sort of warning light for when it was off. Also some ways to make it "automatic". Those were way over my head. Well Dang-it I cant find the thread now. Flyin posted how to wire it up I think and the list of parts. Less than about $8 at Radio Shack.
calperin Posted May 30, 2012 #4 Posted May 30, 2012 Hey, You need to follow the rule.... WE WANT TO SEE THE PICTURES !!!! :cool10::cool10::cool10::cool10:
MikeM Posted May 30, 2012 #5 Posted May 30, 2012 Flyinfool said: Good Luck!!! Don't forget to add an on off switch while you are in there. Never put a switch on mine. I do wait about 5 seconds after turning on the key before I hit the starter button.
djh3 Posted May 31, 2012 #7 Posted May 31, 2012 You don't HAVE to run a on off switch. But what we are saying is it will help save wear and tear on the ballest. There is a protective circuit but into the unit that when it has low volts turns off the light. So when you hit the starter you get this low voltage to light. Essentualy what happens is everytime you start you are doubling the wear and tear on ballest.
