Guest byoung Posted May 29, 2012 #1 Posted May 29, 2012 Just bought an 88 and found the rear shock will not hold pressure. Is there a rebuild option or fix for this problem? If not is anyone parting out a bike or anyone that would have an extra they might let go. The price for the bike was to good to be true, i should have known:depressed: I have already rebuild front shocks and replaced one anti-dive module. Just found out the new replacements from progressive is ~$400. This is much more than I had budgeted to get the bike on the road. Any help is much appericated
friesman Posted May 29, 2012 #2 Posted May 29, 2012 Keep an eye on ebay, i think i spent about 40 bucks plus shipping for a used rear spare shock. or go to Pinwalls ebay shop and see what they have available now. http://stores.ebay.ca/PinWall-Cycle-Parts-Inc/Yamaha-Venture-1983-1993-/_i.html?_fsub=4&_sid=12458664&_trksid=p4634.c0.m322 Actually there are a few here for about 30 bucks each take your pick! http://stores.ebay.ca/PinWall-Cycle-Parts-Inc/Yamaha-Venture-1983-1993-/_i.html?_nkw=shock&submit=Search&_fsub=4&_sid=12458664 But mabbe spray for soapy water on all the connections and see if maybe you just have a leaky air line. Brian
lsutley Posted May 29, 2012 #3 Posted May 29, 2012 I have a complete assembly from my 86. It was replaced with a Progressive unit and was working fine when removed.
Snaggletooth Posted May 29, 2012 #4 Posted May 29, 2012 But mabbe spray for soapy water on all the connections and see if maybe you just have a leaky air line. Brian I thought I had a rear shock going bad on my '84 when I first got it. Found out from the guys here there were very few failures on the 1st gen shocks so I started soaping the air line connections from the compressor all the way through the system. Snugged a few up and it's been fine for years now. Worth a look before the spend the bucks. Mike
Marcarl Posted May 29, 2012 #5 Posted May 29, 2012 Deleted your first thread for you,,, you're welcome. Yep,, check your joints, you might find the cheapest answer,,,,,,air bubbles!
Condor Posted May 29, 2012 #6 Posted May 29, 2012 I thought I had a rear shock going bad on my '84 when I first got it. Found out from the guys here there were very few failures on the 1st gen shocks so I started soaping the air line connections from the compressor all the way through the system. Snugged a few up and it's been fine for years now. Worth a look before the spend the bucks. Mike Make sure it's actually the shock....
Guest byoung Posted May 29, 2012 #7 Posted May 29, 2012 All the suggestions are much appreciated! I will do a soapy water check on the system when time permits. Hopefully before the weekend. This forum is great I love access to "tribal knowledge".
Trader Posted May 29, 2012 #8 Posted May 29, 2012 This forum is great I love access to "tribal knowledge". yep....it takes a village to raise an idiot! worked for me anyway.
Guest byoung Posted June 2, 2012 #9 Posted June 2, 2012 Tried the soapy water check for leaks and could not any. Looks like I need a replacement thanks for suggestions
frankd Posted June 2, 2012 #10 Posted June 2, 2012 You may already know this, but there is a connector underneath the seat, on the right side near the front of the rear tire. How long does it take to bleed down? Frank D.
Guest byoung Posted June 2, 2012 #11 Posted June 2, 2012 This is my first touring bike after many years of riding go fast bikes. I am not familiar with the extras on these bikes. Snaggletooth and Condor mention the compressor and its lines. The manual under section 6 rear suspension only shows the one air line with schrader valve and the dampening adjustment cable and nothing else. I will look for the connector you mentioned tomorrow and hopefully get a better understanding of the setup. It takes about a minute or two to bleed down from 30 or 40 psi. Is there a break down or section in the manual I am missing. I hope so. Thanks for the guidance!
Snaggletooth Posted June 2, 2012 #12 Posted June 2, 2012 I'm assuming the front air pressure is slowing a stable reading and only the rear is dropping in the pressure reading right?
Guest byoung Posted June 2, 2012 #13 Posted June 2, 2012 Upgraded front forks with progressive springs and never added or checked the air pressure on the front. Most posts suggests riding on the new front setup before adding air. Should add 5 or 10psi to front and check to see it holds? Are they interconnected in someway?
Marcarl Posted June 2, 2012 #14 Posted June 2, 2012 Did you check the exhaust port on the pump to make sure the air is not bleeding out through the solenoids?
Snaggletooth Posted June 2, 2012 #15 Posted June 2, 2012 Just checkin'. You mentioned that you had done some work on the front end. They are not linked. As Marcarl mentioned there is the possiblity of the solenoids themselves bleeding through.
rjg1985 Posted June 2, 2012 #16 Posted June 2, 2012 I have a simaliar problem. When try to set the air pressure on the class controller to medium for the rear shock the pump runs for a few seconds the display shows 43 psi. But when I turn off the key and then back on and check the rear pressure it shows 0 psi. If I try the high setting the pump runs until it shows 71 psi. but the bike does not raise. any would be great. Thanks.
Guest byoung Posted June 6, 2012 #17 Posted June 6, 2012 I may have a base model that does not have the CLASS system, is that possible? Where is the display? My model does not have any controls or displays other than the display around the speedo display. I do not see anything else connected to the rear shock. I am feeling a little stupid but this is my first tour bike. Are there any pics of the location of the compressor and or the CLASS control system?
Condor Posted June 6, 2012 #18 Posted June 6, 2012 I may have a base model that does not have the CLASS system, is that possible? Where is the display? My model does not have any controls or displays other than the display around the speedo display. I do not see anything else connected to the rear shock. I am feeling a little stupid but this is my first tour bike. Are there any pics of the location of the compressor and or the CLASS control system? You probably do have a standard. The biggest difference between the Royale and the Standard is the CLASS ride system. The controll sits below the right side hand grip facing up. It sticks out like a sore thumb, and you can't miss it. Some owners have removed the CLASS and gone to manual schraeder valve fill/ adjustment, and a few others have gotten rid of the air ride altogether by installing heavier springs and shocks....
bags529 Posted June 6, 2012 #19 Posted June 6, 2012 Not to hijack. The thread , but what do u need to make the back manual. I got progressives up front nut the back will not hold pressure. Thanks 84 VR 120k brought back from the dead.
Condor Posted June 6, 2012 #20 Posted June 6, 2012 Not to hijack. The thread , but what do u need to make the back manual. I got progressives up front nut the back will not hold pressure. Thanks 84 VR 120k brought back from the dead. Most aftermarket shocks... Progressives included... do not have the air ride as standard, I believe some offer the air as an option. They all are big bucks... Glad I don't have to go that route and resoldering the class board got things going again.
