Squidley Posted May 28, 2012 #1 Posted May 28, 2012 Need some input from the brethren here... I am fixing up Zipcodes '89 Suzuki VS750 Intruder, It needs the fuel petcock screen replaced. I have looked several places on the web, but haven't found just the screens, the petcock works fine. Does anyone know of a place to purchase just the screen, or am I going to have to morf something up While I'm at it, the seat needs to be recovered, any insight on where to just purchase a cover to put over the seat?
BuckShot Posted May 28, 2012 #2 Posted May 28, 2012 Other than a trim shop for the nagahide, I had a trim shop tell me once that Jo Ann Fabrics sell some different good quality nagahide. You might try them. Just a thought.
cecdoo Posted May 28, 2012 #3 Posted May 28, 2012 Need some input from the brethren here... I am fixing up Zipcodes '89 Suzuki VS750 Intruder, It needs the fuel petcock screen replaced. I have looked several places on the web, but haven't found just the screens, the petcock works fine. Does anyone know of a place to purchase just the screen, or am I going to have to morf something up While I'm at it, the seat needs to be recovered, any insight on where to just purchase a cover to put over the seat? Can you eliminate the screens and just put a small inline fuel filter on instead?? Craig
flb_78 Posted May 28, 2012 #4 Posted May 28, 2012 Can you eliminate the screens and just put a small inline fuel filter on instead?? Craig This was my first thought as well. Get rid of the screen and use an inline filter. That way small pieces of rust will not plug up the screen.
Squidley Posted May 28, 2012 Author #5 Posted May 28, 2012 Can you eliminate the screens and just put a small inline fuel filter on instead?? Craig This was my first thought as well. Get rid of the screen and use an inline filter. That way small pieces of rust will not plug up the screen. I have considered that, but this bike doesn't have a gas gauge, and without the 2 different heights on the screens, the reserve is useless, when you run out of gas....your out. Thanks for the insight fellas, do appreciate it
flb_78 Posted May 29, 2012 #6 Posted May 29, 2012 You may also want to check out a Yamaha Raptor 660 fuel valve. A little googling shows a couple applications where various Suzuki folk change out their diaphragm style fuel valves for the Raptor ones. You could probably even buy one locally and return it if it doesn't fit instead of dealing with someone online. http://img847.imageshack.us/img847/3667/img0960a.jpg
Redneck Posted May 29, 2012 #7 Posted May 29, 2012 I have considered that, but this bike doesn't have a gas gauge, and without the 2 different heights on the screens, the reserve is useless, when you run out of gas....your out. Thanks for the insight fellas, do appreciate it From what I hear Dave knows how to run out of fuel even with a reserve so it shouldn't matter.
Squidley Posted May 29, 2012 Author #8 Posted May 29, 2012 You may also want to check out a Yamaha Raptor 660 fuel valve. A little googling shows a couple applications where various Suzuki folk change out their diaphragm style fuel valves for the Raptor ones. You could probably even buy one locally and return it if it doesn't fit instead of dealing with someone online. http://img847.imageshack.us/img847/3667/img0960a.jpg Thanks Forrest, I'll check into that, it looks like it might just work if the diameters of the holes are correct
