There is a malware going around that messes with your DNS or host table, try symantec.com and mcafee.com if you cannot get to both of them you may have it. I got it on my laptop my last trip and had to reloaded it.
Malwarebytes is free. May have to boot up in "safe" mode to install. Sometimes these viruses keep you from installing software to elminate them.
works for me i did have trouble on the desk top i loaded set dsn like i have on laptop no problems now
and thanks for the link rick i need a jacket boots chaps and stuff now ive got my wish list growingby leaps and well i beter set boundries i cant afford everything on the site
Edited by pmelah
Well I ran a scan and no issues found. I could also open both the links that etcswjoe suggested with no issues so not sure what is up. This is the only site I am having trouble with. I really need on the sight though. Not sure what to do.
Rick did you try another computer in your house? Check your firewall to make sure its not blocked for some reason. Also what error are you getting when you try it? Also go to this site http://www.dns-ok.us/ it will tell you if your DNS is good or not.
Hmm do you maybe have another browser installed like chrome? My company web site will not allow me on with IE, but works with chrome. I can use IE from any other computer in the house and get on just not mine. :confused24:
I use Chrome and have never had a problem. I also tried other browsers today and it still doesn't work. I ran the malwarebytes program and no issues found.
I ran the dns check and everything was fine, i turned off my firewall and tried in and still wouldn't come up. I hooked up the computer direct instead of through the wireless router and still nothing. I am dumbfounded.
I went to my daughters computer and it worked fine. So something in mine I guess. I shut off the anti virus and it still will not work.
Here is their IP address 72.26.99.210 see if it works.
nope will not work. All that comes up is a blank white screen with "5b4" in the upper left corner
Same thing fuzzy. 5b4 in corner and a blank screen otherwise.
I guess I will have to use my daughters or the one clear down 3 flights of stairs in the basement:confused24:
I know you did other virus test, but how about a defrag and clean up ? Try that maybe.
Fuzzy
Fuzzy
I just found it won't let me on amazon either so has to be a setting in my computer.
