spider Posted May 27, 2012 Posted May 27, 2012 I'm looking for a trailer and have looked at 2. Both were Aluma MCTXL models, one new one used. They both had a little water standing in the bottom. Are they leaking or is that condensation? If, like I suspect it's condensation, will it be an ongoing problem? I was thinking about putting insulation and carpet in it but I don't the carpet to get wet and mildew. How do you keep yours dry? Thanks Rex
Rick Haywood Posted May 27, 2012 Posted May 27, 2012 http://minitrailerusa.com/ Check these out also, already has carpet. I would suspect the water is a leak. When people put on the luggage rack they forget to silicone the holes.
Rickster Posted May 27, 2012 Posted May 27, 2012 I bought an America's Best trailer off E Bay it's an Escape and playboy has the Escape XL from the same company. I'm very happy with it and it looks just like the Trailers your looking at. http://rover.ebay.com/rover/1/711-53200-19255-0/1?campid=5335830059&toolid=10001&mpre=http%3A%2F%2Fwww.ebay.com%2Fitm%2FAluminum-Motorcycle-Trailers-Tow-Pull-Cargo-Behind-Harley-Goldwing-anything%3Fitem%3D170824964025&cmd%3DViewItem&_trksid%3Dp5197.m7&_trkparms%3Dalgo%253DLVI%2526itu%253DUCI%2526otn%253D4%2526po%253DLVI%2526ps%253D63%2526clkid%253D7747357277981478025%23ht_12476wt_812
Motorcycle Mike Posted May 27, 2012 Posted May 27, 2012 There is caulking around the edge of the diamond plate on the top. Mine devolped a small leak there. A little fresh caulk and I haven't had a leak since. No condisation either. Everything stays dry as a bone.
