In the Ohio restaurant forum??? Yamamama & Freebird the only members with access? It tells me I may not, may not, may not. Last entry was April 18, 2010.
Rumor has it that you didn't leave a big enough tip....:confused24:
Just a rumor I started seconds ago..... :no-no-no:
Yeh, well, rumor has it that with a valuable response like this, I probably have a tip for you.
Interesting. I can't post either. Checked the thread introducing the setup. There was to be a form to fill out that would automatically populate the restaurant review in the correct state. Don't see where this form is available. If it is hidden somewhere, perhaps it should be stickied to the top of the restaurant review section.
Freebird to the white courtesy phone please.
RR
PS. KIC is our local curmudgeon. If he's not poking you, then start to worry.:stickpoke:
OK, found it.
Go to forums, scroll down to Member Restaurant Reviews. There is a link for the form right under the forum header. 'Click here to submit your favorite Restaurant'. Click the link and it takes you to the form.
Freebird, disregard the message on the white courtesy phone.
JJ
