Keitho Posted January 10, 2008 #1 Posted January 10, 2008 When doing maintainance on the rear wheel hub assembly, is it okay to use "white lithium" grease, on the splines and hub pins,or is there another type to use? I know that some people have complained about the lack of grease in this area, the white lithium looks like it may be too light for the job. I had to pry the hub out of the assy using a pry bar, it was rusted in there good, no sign of any grease from the factory. I cleaned of the pins with a wire wheel and cleaned the bore's out with a .20 gauge smooth bore barrel cleaning tool, you know what I mean the copper brush thing, lol. Yes ay info on what type of grease to use would be helpful. Cheers Keith.
Guest KitCarson Posted January 10, 2008 #2 Posted January 10, 2008 You should use Moly based grease......lithium is too light.......will wash away.....all the treads that complain about there being no grease on the drive shaft and the rear drive and pins.....are partly right....Moly grease continues to be present and work long after the base material is gone from heat. It is a substance similar to graphite....and works even when dry. There are also several new synthetic ones out if you can find them.......Lithium just does not do it........one of the best is the moly based tacky grease......like used on heavy equipment.
Keitho Posted January 11, 2008 Author #3 Posted January 11, 2008 Thanks Kit, I will have to go and get me some of that. Keith.
Squidley Posted January 11, 2008 #4 Posted January 11, 2008 Keith, I had been using a synthetic blend by valvoline with Moly, but it still seemed to run out of the hub assy and onto the rim as I was always cleaning it when I washed my bike. Before Lonna and I did our trip down south over Christmas (the one where we crashed on the bike) I took the rear tire apart and used Royal purple grease. I have to tell you this stuff is sticky like molassas and we had about 1200 miles on it before the accident and it doesn't seem to have leaked off. We use this stuff in bearing at the power plant and it is amazing, I would suggest trying that as it will be all I use on the rearend from now on
Guest KitCarson Posted January 11, 2008 #5 Posted January 11, 2008 I forgot about Royal Purple........that is one of the synthetics I was talking about......I use the gear oil in the rear drive of bikes with a drive shaft. I vote for Royal Purple also.......had just forgot about that for a moment. You can purchase Royal Purple at places like Advance Auto Parts.....O'Reilly, Napa and places like that. Even some of the Yamaha Dealers are slightly hinting to use it.
Guest Yamahawg Posted January 11, 2008 #6 Posted January 11, 2008 Hey Squidley, (not trying to steal the thread but), if your font gets any smaller im gonna hafta get a Magnifying glass to read it.
2WHEELSFORME Posted January 11, 2008 #7 Posted January 11, 2008 I've been using white lithium grease on three bikes for over 80k miles and it is always still present when I put on new rubber.
KeithR Posted January 11, 2008 #8 Posted January 11, 2008 I have been using Lucas Red N Tacky....seems to be doing the job http://www.lucasoil.com/products/display_products.sd?iid=46&catid=2&loc=show Keith
Eck Posted January 11, 2008 #9 Posted January 11, 2008 Hey Squidley, (not trying to steal the thread but), if your font gets any smaller im gonna hafta get a Magnifying glass to read it. DITTO........I was "squinting" trying to read it.. Your font size doesnt help us older folks there Squid
Pilot Posted January 11, 2008 #10 Posted January 11, 2008 Keith, I had been using a synthetic blend by valvoline with Moly, but it still seemed to run out of the hub assy and onto the rim as I was always cleaning it when I washed my bike. Before Lonna and I did our trip down south over Christmas (the one where we crashed on the bike) I took the rear tire apart and used Royal purple grease. I have to tell you this stuff is sticky like molassas and we had about 1200 miles on it before the accident and it doesn't seem to have leaked off. We use this stuff in bearing at the power plant and it is amazing, I would suggest trying that as it will be all I use on the rearend from now on Like Squidley I used Coastal Premium EP Moly Grease I picked up at Auto Zone and it also runs out onto the wheel. Next time I'm switching. All Moly grease is not created equal...
Keitho Posted January 11, 2008 Author #11 Posted January 11, 2008 Thank you all for the feed back. I will pop into my local automotive store NAPA to see if this Royal Purple is available up here in the great white north. Thanks again. Hey Sqid I hope that all goes well with you and you missis, Take care mate. Keith.
Squidley Posted January 12, 2008 #12 Posted January 12, 2008 Thank you all for the feed back. I will pop into my local automotive store NAPA to see if this Royal Purple is available up here in the great white north. Thanks again. Hey Sqid I hope that all goes well with you and you missis, Take care mate. Keith. Thanks Keith, Were holding our own right now If you have problems finding it let me know and I'll get a tube of it and get it to you
Keitho Posted January 14, 2008 Author #13 Posted January 14, 2008 Thanks Brad I may have too take you up on that. I will check out this week to see if it is available. Keith.
rjmalizia Posted January 14, 2008 #14 Posted January 14, 2008 Hey Cats! (been a while) YamaHawg... Hey Squidley, (not trying to steal the thread but), if your font gets any smaller im gonna hafta get a Magnifying glass to read it. in the browser of choice...you can always change you font size by using the following key combinations: Ctrl++ [that's Control+[the plus key]] to go bigger with the font, and... Ctrl+- [that's the Control+[the minus key]] please give it a try.. later all
Guest Yamahawg Posted January 19, 2008 #15 Posted January 19, 2008 rjmalizia ....Cool... tried it and it works... Will remember that one. Thanks.
