TxVenture Posted January 10, 2008 #1 Posted January 10, 2008 When I had the fairing off fixing broken areas I found that the CB/Air ride panel mount system was broken. What I am trying to describe is on the underneath side of the panel there are 6 supports that the mounting screws go thru. These supports were broken or cracked and would not support the panel properly. I went to a local lumber chain store and got a 3/4" dowel rod. I then drilled a hole about 2" deep centered on the end. Then I cut 6 pieces 5/16" long. Now I had 6 individual pieces 5/16" long with a hole thru the center. The 2 that are at the rear of the panel will have to have one side trimmed off because the panel narrows at that end and 3/4" is to wide to fit. Then I used a product called Automotive Amazing Goop which can be bought at Walmart for $3 and change to glue the wood pieces to the underneath side of the panel. Don H.
Tnventurer Posted January 11, 2008 #2 Posted January 11, 2008 :photographing:Hey sounds Great Don....But Need pics!....Fred
