EnJay Posted May 21, 2012 Posted May 21, 2012 I'm wondering what make/model digital tachometer is being used out there for diagnostics. I have an 84 VR MK1 and need to make some adjustments that require a digital tach. Before I make a purchase I would like to see what you guys are using and whether you like it or not. So; whatcha using?
twigg Posted May 21, 2012 Posted May 21, 2012 I'm wondering what make/model digital tachometer is being used out there for diagnostics. I have an 84 VR MK1 and need to make some adjustments that require a digital tach. Before I make a purchase I would like to see what you guys are using and whether you like it or not. So; whatcha using? There are quite a few to choose from. A search of Amazon will drag a few up. You might want to consider getting one of the better Multi Meters with an inductive pickup simply because they are more flexible. Decent ones can be had in the $40 to $70 price range. Adjusting the Idle Mixture requires a decent digital tach, unless you have an exhaust gas analyser.
dingy Posted May 21, 2012 Posted May 21, 2012 Link below to item on ebay http://www.ebay.com/itm/Hour-meter-sx-KTM-exc-mxc-xc-mx-sxf-sxf-250-450-520-525-xc4-lc4-530-excr-smr-sx-/370613484284?pt=Motorcycles_Parts_Accessories&hash=item564a48fafc Seller is ozg-motors In addition to listing heading that says it is hour mter, it is also a digital tach. You don't need to connect ground to get tach to work, just wrap wire around spark plug wire. I did a group buy for 30 of these here a couple of years ago. Gary
Snaggletooth Posted May 21, 2012 Posted May 21, 2012 Link below to item on ebay http://www.ebay.com/itm/Hour-meter-sx-KTM-exc-mxc-xc-mx-sxf-sxf-250-450-520-525-xc4-lc4-530-excr-smr-sx-/370613484284?pt=Motorcycles_Parts_Accessories&hash=item564a48fafc Seller is ozg-motors In addition to listing heading that says it is hour meter, it is also a digital tach. I did a group buy for 30 of these here a couple of years ago. Gary And it's still working just dandy thank you very much Gary. Handy lil sucker when ya need it. Mike
EnJay Posted May 22, 2012 Author Posted May 22, 2012 Thanks Gary and Mike. I just ordered myself a KTM. I do appreciate your help.
