stardbog Posted May 20, 2012 Posted May 20, 2012 Hey Gals and guys, I will try to get Iron Butt ride to Don's Maintanance Day. All options are open, here's rout I was planning, but once again nothing is carved in the stone. Iron Butt Route Does anybody want to join me ?? First 6 Beers are on me at Don's ( after ride )
Flyinfool Posted May 20, 2012 Posted May 20, 2012 I'll be going thru Chicago at around 5-6am on Friday morning. But I'll never make Iron Butt, I'm, still working my way UP to marshmallow butt.
stardbog Posted May 20, 2012 Author Posted May 20, 2012 Cool Jeff, I'll be gone by 5 AM. see you at MD:sign yeah that:
Rick Haywood Posted May 21, 2012 Posted May 21, 2012 you might want to check but as of 6 weeks or so ago the bridge on I-64 into Louisville was closed. Just and FYI
RedRider Posted May 21, 2012 Posted May 21, 2012 Dan, Please be aware of the limitations of Google Maps. Your routing takes you to the center of each city. Likely, you intend to skirt around the outside and stay on the interstates as heading into the cities will kill your time. I plugged your route into Streets and Trips starting at the Irving Park train station. I rounded off the corners at the target cities and found the route is 1025 miles. This is also to Oberlin, not necessarily to Don's (or a gas station near Don's). 1025 is cutting it a little close, but is doable (if you have your route corners documented very well). In addition to the corners (StL, Cleveland), you will need to document a stop in Lexington and in Cambridge, OH as these indirect locations are imperative to make this route 1000+. Might I suggest a slight modification. Continue east on 64 to Charleston, West b'God Virginia and then head north on 77. Once you get to New Philadelphia, OH, you can kick NW and head directly to Don's. This route provides 1042 miles (again, to Oberlin, not necessarily to Don's). Assuming this route will take approx. 20 hours to ride (direct, non-stop is 15.5 hours), and you get on the road at 5am, you will be able to enjoy the beautiful ride thru WV and southern Ohio in daylight. As boring as most of these slabs are (I-55 thru Illinois is painfully boring), I-77 thru WV is wonderful. The documentation would be fairly easy with Start, St. Louis area, Charleston area, and End (along with all your gas receipts, signed forms, etc.). However you go - good luck. Should be a great ride. Wish I had time to join you. Hopefully, I can get to Don's next year. RR
stardbog Posted May 21, 2012 Author Posted May 21, 2012 Jeff thats great idea, I was thinkig same to go trough WV and than go notrh towards Cleveland. Cool man thanks for your advice, I will definitly choose that route:sign killer dude:
spider Posted May 21, 2012 Posted May 21, 2012 you might want to check but as of 6 weeks or so ago the bridge on I-64 into Louisville was closed. Just and FYI The bridge is open but traffic during rush hour can be stop and go, some times more stop than go. Good luck. Rex
twigg Posted May 21, 2012 Posted May 21, 2012 What Jeff said A few things to bear in mind .... If possible, plan to be passing the busiest city on the route well away from rush hour times. Carry plenty of fluids on the bike, and drink regularly. Take it easy. The SaddleSore pace is not difficult. No need to rush. I would set the cruise at about 65mph on the Interstate, and just enjoy the ride. Get a gas receipt at each corner and at least every 300 miles. Try to get ahead of the clock by keeping the early stops as short as you can. The way to build miles is to keep the wheels turning, not to ride fast. If you manage that you will find the second half of the ride much easier. Plan to finish in daylight. Have fun and if you are using a GPS, submit the Track Log with the receipts, it makes verification easier, esp. if the miles are on the short side of comfortable.
dacheedah Posted May 21, 2012 Posted May 21, 2012 I'm takin off once the wife is off work on friday, guessing like about 3:00 - 4:00pm from K3. Pullin a trailer and 2 up. . .
