Ok, going with my basic knowledge of electronic stuff of which I have er........ NONE, I would guess one of you wizards out there can fill me in.
I have a gizmo that is powered by 3 AA batteries so I'm looking at 4.5 volts. See, I can figure some stuff out. I would assume, and I do love that word, that it would be possible using resistors or other unknown objects I have have no idea of that I could reduce the bikes 12 volts down to 4.5 to power this gizmo with a hardwire setup.
So tell me wise ones...... what am I looking for to pull this off?
Mike
aka Sparky
Ohm's law comes into play here.
You would need to know the devices current draw to calculate the size of resistor needed.
Gary
Dingy is correct,
you need to check how much current are you use on your gizmo with your 4.5 V AAA bateries. Do you have a multimeter? if the answer is yes, put it on AMP, and the higher scale you have on it. Put the multimeter between the positive end of the battery and the gizmo. And the other side of the gizmo connected to the negative.
Check the amperage, and the way to get the right resistor will be : (12v-4.5V)/(amperage reading). Also the power that the resistor will dissipate is (7.5V)*amperage.
So when you purchase the resistor, not only you need to choose it for his value, but also for the power that is able to dissipate.
Good luck....
:detective::detective::detective:
It might be safer/easier to just use a LM7805 regulator or a LM317T adjustable regulator. Odds are you are pulling less than 1 amp.
The problem with using just a resistor is that you may get weird results as the bike voltage changes, or the device current draw changes.
Go to radio Shack or Wally world or Target and buy one of those universal adapters that plugs into a cigarette lighter and has a switch to select whatever voltage you need...
I probably have a half dozen old car phone chargers in a cabinet around here. I can look and see what I got and send you something. I'd hate to see you let out the magical blue smoke. DJ's theroy on electricity. you need power and a ground and you dont want to be in between.:080402gudl_prv:
The adapters for charging a USB device puts out 5v. That should not be a problem for your 4.5v gps.
Resistance is not all you need to worry about. Currant draw is also a facter which then brings the third factor which is heat. The amount of currant drawn through a given resistance creates heat. Increase either one and the heat generated also wil increase.
There are all sorts of ready made voltage supplies and convertors out there you should be able to find the one you need woth out having to mess with the above.
Yes! The resistor will be a linear device, buying a cheap phone charger or usb device will be regulated somewhat.
I installed a cigar lighter on my Vulcan, just to power such items, and to protect the less than bulky wire I ran for the lighter plug, I used a self-resetting 2amp circuit breaker
I have a resistor on my scoot that works for almost anything. If there is too much voltage it gets switched to amperage on the fly, and if the amperage gets too hot, it dissipates through the helmet. I have not tested it for small items, seeing as I don't have a small item situation, but I am sure that if I had a small item that would be resisted as well. As far as letting out the smoke is concerned, if and when that should happen, I suggest leaving the scoot where it's at and run for safety.
