05Venture Posted May 12, 2012 #1 Posted May 12, 2012 I read where the 1156 bulb would replace the rear turn signal but it doesn't seem to fit. Can someone tell me what bulbs will work form say autozone, etc? the 1156 doesn't have the offset pins like the stock bulb. Thanks for any assistance..
Brake Pad Posted May 12, 2012 #2 Posted May 12, 2012 I would just take the bulb with you when you look, and have a sales person help you with your purchase
Hotrod Posted May 12, 2012 #3 Posted May 12, 2012 Just hold your old bulb up to the new ones and compare the pin alignment.File off one pin on the 1156 that doesn't line up.Been awhile since I did mine, but I replaced mine with 1156 SilverStar bulbs. If you file the wrong pin, you are not out very much money.Buy some more and you will learn from your mistake.The bulb only needs 1 pin on the new bulb to hold.I replaced mine in 2007 and have never had a problem.
allwx Posted May 12, 2012 #4 Posted May 12, 2012 I like the oem bulbs from Yamaha. They are a bit more expensive, but when you hold the oem bulb beside one of the cheapies from Autozone, you can readily see the diff.
05Venture Posted May 12, 2012 Author #5 Posted May 12, 2012 Hotrod said: Just hold your old bulb up to the new ones and compare the pin alignment.File off one pin on the 1156 that doesn't line up.Been awhile since I did mine, but I replaced mine with 1156 SilverStar bulbs. If you file the wrong pin, you are not out very much money.Buy some more and you will learn from your mistake.The bulb only needs 1 pin on the new bulb to hold.I replaced mine in 2007 and have never had a problem. Worked like a charm!!!
