hunter 1500 Posted May 7, 2012 #1 Posted May 7, 2012 Anyone ever run a Dunlop 404 on the rear. I have a wheel and tire that I got from Pinwall that has a brand new 404 on it. I just wanted the extra rim for $100 bucks and was thinking about going to the darkside.
Carbon_One Posted May 7, 2012 #2 Posted May 7, 2012 My bike came with the 404's. Better tire than the Bridgstones that some have came with, thou the Avons seem to be the tire of choice for replacements
hunter 1500 Posted May 7, 2012 Author #3 Posted May 7, 2012 Carbon_One said: My bike came with the 404's. Better tire than the Bridgstones that some have came with, thou the Avons seem to be the tire of choice for replacements I have run the brickstones and I like the Comander II and the E3 and have given some thought to the darkside. Thanks I thought probably that was the case because this is a brand new rim and tire w/out the disk so I will swap that over.
etcswjoe Posted May 7, 2012 #4 Posted May 7, 2012 I have 404' on one bike and will be replacing the rear soon, they wear out fast.
wes0778 Posted May 7, 2012 #5 Posted May 7, 2012 If it is an new OEM 404, I'd run it. No not the best handling tire, but I got more than 10,000 miles out of an OEM. On the other hand I only got about 6500 miles out of an aftermarket replacement 404.
OB-1 Posted May 7, 2012 #6 Posted May 7, 2012 404's are good tires and often used as OEM tires. My only complaint about 404's is poor tire life. I only got about 6K miles out of the one on the rear of my RSV. I get 10-12k out of an E-3, Avon Venom, and/or Michelin Commander. YMMV
Sylvester Posted May 7, 2012 #7 Posted May 7, 2012 I get 10k + miles out of D404 on the rear and 14-15 k on the front. I have been running them for the last 100k miles on my 02 RSMV and will buy another set when needed.
RSTDdog Posted May 8, 2012 #8 Posted May 8, 2012 I have read somewhere here that there were two versions of the 404 and one lasts longer than the other. Someone wrote there was a difference in the sidewall markings. It was in a tire thread and there are only "a few" of those on here so should be easy to find in search..... Certainly no harm in running it. One less tire you have to buy, RSTDdog
rickardracing Posted May 8, 2012 #9 Posted May 8, 2012 404's are crap tires. If I am going to go through the effort of replacing the bcak tire, free or not, I would spend the mone and put the E3's on. Why replace crap with crap? Jusy my .02
sarges46 Posted May 9, 2012 #11 Posted May 9, 2012 Last year I blew out the rear tire on our way down to Cody. It was replaced in Bismarck with a 404. 3000 miles later I need a new tire. There are a couple factors that will contribute to this poor performance but not this much me thinks. I was towing a camper trailer, rode some 30 miles or so in gravel. Terrible mileage.
Kirby Posted May 9, 2012 #12 Posted May 9, 2012 I average 20-25k miles a year and I had 404's on my 09 when it was new and got reasonably good service out of them. Granted they are not the best tire out there, but I got mileage similar to what Sylvester said, 10-12k out of the rear and about 14-15k out of the front. These were the tires that came on the bike and it has been speculated that the OEM tires are a better grade than the ones you buy afterward. I don't know about all that but any tire that gets me that kind of mileage is a pretty good tire in my book. I currently am trying out the Avon Venoms. So far they're about the best I've found for the rear and that includes the E3. We'll see how they hold up in the long run. The next best tire would have to be the E3. They just howl like crazy, but other than that, very good. If they made a Avon Cobra in a size to fit the rear of the RSV, I'd buy that one next. I had a Cobra on the front for 20K miles before it got a cut in it and I had to change it out. I had the Cobra on the front when I toyed with the car tire and it was great!! After saying all that I have to add that not everyone's riding habits are the same. That's why one guy says he just loves the Pirelli Route 66 or the Shinko and I can't get 6,000 miles out of the ones I've tried. That's why I keep switching around. When I find the ultimate combo that works for me, I'll stick with it. You should do the same and take opinions with a grain of salt. That includes mine.
hunter 1500 Posted June 25, 2012 Author #13 Posted June 25, 2012 That tire is toast already. Got maybe 4 k out of it.
Guest tx2sturgis Posted June 25, 2012 #14 Posted June 25, 2012 Kirby said: I When I find the ultimate combo that works for me, I'll stick with it. Just when that sounds like it will work, the manufacturers will change a tire compound or discontinue making the ones you like. Just like household light bulbs, the less durable they are, the more of them they can sell.
Kirby Posted June 25, 2012 #15 Posted June 25, 2012 tx2sturgis said: Just when that sounds like it will work, the manufacturers will change a tire compound or discontinue making the ones you like. Just like household light bulbs, the less durable they are, the more of them they can sell. I agree.
BradT Posted June 26, 2012 #16 Posted June 26, 2012 If it is new it is worth putting the wheel on and trying the tire. If you don't like it change it. Even a few thousand miles is worth the try even if you hate it, replace it. I have no problem with them and get 10,000 miles easily everytime. I run the WWW and have 14,000 miles on this set and not planning on changing it for a bit or a trip comes up. Brad
KDFranzen Posted June 26, 2012 #17 Posted June 26, 2012 Mine came with the 404's. The bike already had 2500 miles on it when i boought it. I ended up changing both the front and rear with another set of 404s. The mileage was 14255 when I changed them. I too was worried about a change in compound. I guess we'll see.
