skydoc_17 Posted May 8, 2012 #101 Posted May 8, 2012 Hey Mike, I wanted to let you know that I have shipped a Brand New HO Stator, and a Complete Gasket Set out for the Install, first thing this morning! You should have it before the weekend. I apologize again for this defective part, but am sure that this new part will get you back on the road in no time at all. Earl
twigg Posted May 8, 2012 #102 Posted May 8, 2012 Hey Mike, I wanted to let you know that I have shipped a Brand New HO Stator, and a Complete Gasket Set out for the Install, first thing this morning! You should have it before the weekend. I apologize again for this defective part, but am sure that this new part will get you back on the road in no time at all. Earl First thing, Earl, is that it is more than decent that you have covered this failure, even without knowing what caused it. It may have been a faulty Stator, but it will be important that Mike does some detective work or te risk is that this one may go the same way as the last. No one wants two failures!
reddevilmedic Posted May 8, 2012 Author #103 Posted May 8, 2012 First thing, Earl, is that it is more than decent that you have covered this failure, even without knowing what caused it. It may have been a faulty Stator, but it will be important that Mike does some detective work or te risk is that this one may go the same way as the last. No one wants two failures! not me for sure! i will look into the cooling wire situation. it does have the cooling pieces installed. i noticed that with the first stator replacement. but, i will pull bolt out and check for wire. im going out of town tomoorow and wont be back till late sunday. i will post my findings monday. thanks for your help on this.
