djh3 Posted May 7, 2012 Posted May 7, 2012 (edited) HID kit came with a relay & harness. Before I installed toggle switch, I supplied power to relay (to turn on) from my aux fuse box which is in turn supplied power after a relay is turned on with the key. Does that sort of make sense. Anyways I installed my toggle switch in the ground side of the realy. That was easiest I thought. I just pulled the ground lug out of the harness, plugged into one side of switch and installed the other side of switch wire into the harness plug/relay. Basicly I'm trying to figure out how many wires I'm going to have torun back up the handlebars and under the fairing. I like to hide it in some black tubing like it is now to look more factory. In you directions you say I need a resistor but didnt mention where it was installed. If I was to guess solder it to the power side of the LED and then solder that to the switch? I dont want to cut into the wiring on the bike. I should be able to just tap in where my power comes into the HID relay and switch it instead I think. OK not the greatest but maybe this will see if Im on the right track. Edited May 8, 2012 by djh3
Guest Posted May 13, 2012 Posted May 13, 2012 Got the switch in the other day. Thanks again, Larry!!:smile5:
djh3 Posted May 14, 2012 Posted May 14, 2012 I was just on e-bay looking at LED lights, the type that are a replacement for a standard type bulb, not the high dollar whole nechallada thing. Anyways did run across a store there that had time delay relays. Went anything like from 0-30 sec to 0-10 min to as high as 0-60 min. I would think you could set say a 0-10 min one to like a min and that would give you plenty of time to start etc. But I bought the parts to make Flyin's blinky LED warning light switch.
