utadventure Posted May 9, 2012 Posted May 9, 2012 Here's a variation Sam and I came up with last night.
Flyinfool Posted May 9, 2012 Posted May 9, 2012 I was thinking along the lines of drilling and tapping and counter boring the exposed end to put in a hex socket head cap screw with red Loctite. This way you would have a hex drive for install and removal and no visible drive on the outside of the Snagglebar. Unless of course you have access to the technology to make a hex hole into the end of the bar.
twigg Posted May 9, 2012 Posted May 9, 2012 Do these replace the nut on the end of the bolt ? They go on AFTER the handlebar nut is torqued. You do know that the nut holding the handlebar is the weakest link? :rotf:
KIC Posted May 9, 2012 Posted May 9, 2012 They go on AFTER the handlebar nut is torqued. I looked at both my 87 and 89 and neither one has any threads available to use if the nut is on the bolt. So..... do you use a longer bolt or a thinner nut ? Inquiring minds want to know...
Wanderer Posted May 9, 2012 Posted May 9, 2012 I looked at both my 87 and 89 and neither one has any threads available to use if the nut is on the bolt. So..... do you use a longer bolt or a thinner nut ? Inquiring minds want to know... The extensions replace the nut.
bilko1 Posted May 9, 2012 Posted May 9, 2012 I looked at both my 87 and 89 and neither one has any threads available to use if the nut is on the bolt. So..... do you use a longer bolt or a thinner nut ? Inquiring minds want to know... I wish I was a thinner nut.
Venturous Randy Posted May 9, 2012 Posted May 9, 2012 This is how I mounted my GPS and it works very good and is not in the way whenever I don't have the GPS on he bike. I used a piece of 1/4 in plexiglass that I trimmed to fit the base on the mount. RandyA
Snaggletooth Posted May 9, 2012 Author Posted May 9, 2012 I looked at both my 87 and 89 and neither one has any threads available to use if the nut is on the bolt. So..... do you use a longer bolt or a thinner nut ? Inquiring minds want to know... The nut gets removed..... forever! (or somewhere you can find it later anyway) The stud is threaded to replace the nut with 10mm X 1 pitch to match the bolt from the controls. The controls from both sides are held in place by a splined shaft that seats into the riser. So that allows for the up and down adjustments to the controls. Pay attention when you look at that as there is a pin in that connection that limits how far up and down they can be moved. If that pin does not align with the slot it will bind and not seat properly. Once the controls are set where you want them there are the two pinch bolts on the risers that bind it in place. The nut itself, or the stud replacing it does hold the controls on, but the pinch bolts do most the securement. I tighten the studs down then hit the pinch bolts and it ain't going anywhere. If you remove that nut and look inside the riser you will see what I'm talking about. Mike
Snaggletooth Posted May 9, 2012 Author Posted May 9, 2012 Here is the drawing if you want to use it. Very sharp Idea there Jeff. I filed that one in my "improvement" notes. Thanks. Mike
motorcycle.jockey Posted May 24, 2012 Posted May 24, 2012 Any more information on if/when these might be available? I have a trip in a few weeks and a set of these would be handy.
Bob Myers Posted May 24, 2012 Posted May 24, 2012 I'll have material tomorrow! Should have a few ready to ship on Friday.
Snaggletooth Posted May 24, 2012 Author Posted May 24, 2012 I'll have material tomorrow! Should have a few ready to ship on Friday. Thanks for in update Bob. Good to know. One of my extras turned into the Snagglestud Camera Mount. These types of studs are pretty handy for about anything.
Snaggletooth Posted May 24, 2012 Author Posted May 24, 2012 Not really, much better than I expected. The mounts I made for the upper fairing were much worse. I made another shorter one for the saddlebag guard and it's fine also. Just swap the camera back and forth with the quik-disconnects in a couple seconds. Now I just need to head off to someplace really interesting. Mike
friesman Posted May 24, 2012 Posted May 24, 2012 Not really, much better than I expected. The mounts I made for the upper fairing were much worse. I made another shorter one for the saddlebag guard and it's fine also. Just swap the camera back and forth with the quik-disconnects in a couple seconds. Now I just need to head off to someplace really interesting. Mike THats good Mike, you just get the details worked out with the Drift mounting and Ill wait and see what works best for you ...and then do it too....that saves so much time..... Brian
Bob Myers Posted May 24, 2012 Posted May 24, 2012 I'd love to see some video from this camera, I'm always looking for a better cam for our trips. I use a FLIP now, which is fantastic-for a handheld, only records an hour though
RJClubb410 Posted May 27, 2012 Posted May 27, 2012 Question what is wrong with velcro to the tank lid? It is stream lined and not in the way of the gauges....
Bob Myers Posted May 29, 2012 Posted May 29, 2012 Thanks for in update Bob. Good to know. One of my extras turned into the Snagglestud Camera Mount. These types of studs are pretty handy for about anything. These aluminum stubs/mounts are likely to be called "Snagglemounts" from here out. If any one is interested there will be several pairs shipping today. One is drilled/tapped 5/16-18 as per Snagglemounts father:rotf:, and the other is plain. If my bolts get here in time there will be a button head screw in place to close off the threads until you want/need them.
motorcycle.jockey Posted May 31, 2012 Posted May 31, 2012 Are there any still available, if so how do I order? Sent from my VTAB1008 using Tapatalk 2
Bob Myers Posted May 31, 2012 Posted May 31, 2012 Question what is wrong with velcro to the tank lid? It is stream lined and not in the way of the gauges.... I see nothing wrong with doing that. My only hesitation is the adhesive used on the piece attached to the cover, and the effects of whatever chemical is used to remove the adhesive.
