oldbutnewrider Posted May 3, 2012 #1 Posted May 3, 2012 Tried searching but struck out.... Has anyone installed Venture passenger grips on a RSTD? I am not installing a trunk yet but will in the future but wanted to try to adapt these stock venture assist grips.... Any help or pics would be outstanding.... Thanks in advance.... Bob
Carbon_One Posted May 3, 2012 #2 Posted May 3, 2012 Joe ( star4772 ) added a set to his RSTD, but also added a Wing trunk. Here's his post -- http://www.venturerider.org/forum/showthread.php?t=69186&highlight=trunk Larry
RSTDdog Posted May 4, 2012 #3 Posted May 4, 2012 The venture passenger hand grips attach to the side rails and to the Venture Trunk mount bracket. If you are not using the trunk mount bracket you would have to fab or modify where/how that end of the mounts attach. I can't recall seeing it done by anyone with out the trunk bracket.
Eck Posted May 4, 2012 #4 Posted May 4, 2012 I would just tell the passenger to hold on.... then sit back and let them hunt around and find something to grab on to...
Carbon_One Posted May 4, 2012 #5 Posted May 4, 2012 The venture passenger hand grips attach to the side rails and to the Venture Trunk mount bracket. If you are not using the trunk mount bracket you would have to fab or modify where/how that end of the mounts attach. I can't recall seeing it done by anyone with out the trunk bracket. RSTDdog is right here. I had forgotten Joe used the RSV luggage rack to mount his trunk. Larry
