the front right brake line that links to the fork (see Photo). Does anyone know where to get one? It's for a Venture Royale 1983...
Thank you for the help.
If you just need the line from the caliper to the anti-dive unt I MIGHT still have my old set around. I may have tossed them but I'll take a look if you need it.
If needed you can swap out the long union bolt on the caliper for the short union on the anti-dive and cap off the the anti-dive port to eliminate the lines and the AD all together.
Mike
I will in the future do an upgrade to the fork system, but in the mean time I will replace that hose. If one of you would like to give me a good price I would appreciate it. I can be reach at CASIPER@GMAIL.COM
Thank you all.
I have one as well from my 85 but i might suggest that maybe you take Greg's advice. then you"ll have a fresh new rubber hose or steel. If theres a truck supply store near you they may be able to make up for you.
