pmj423 Posted April 25, 2012 #1 Posted April 25, 2012 So I installed 1.5" riser on the handle bars today. All the lines look like there is plenty of play in them. I was not able to re install the rubber mounts for the fairing. Have to think about that for a while before I modify them. Any suggestions are appreciated. The one other problem I found is the mounts now hit the plastic cover on the gas tank by the key. They don't touch the ignition but do move the plastic. I am looking for another one that I can modify. Preferably in Black but any color will do. if anyone has an extra they are willing to part with please let me know. Thanks much
Kregerdoodle Posted April 25, 2012 #2 Posted April 25, 2012 Sorry can`t help ya, I have seen that on a freinds bike, and can`t really say what he did to fix the problem:confused24: If I find out I`ll let ya know..
spitfire9 Posted April 25, 2012 #3 Posted April 25, 2012 Check that ebay store i posted. Pinwall cycles I thought i saw some there.
Rick Haywood Posted April 25, 2012 #4 Posted April 25, 2012 I cut the rubber pieces down and installed them on the top of the handle bars up against the fairing. As for the handle bars hitting the ignition cover I didn't do anything to mine and unless I am turning really sharp in the parking lot it doesn't hit and when it does it just moves it a little.
pmj423 Posted April 25, 2012 Author #5 Posted April 25, 2012 Rick Haywood said: I cut the rubber pieces down and installed them on the top of the handle bars up against the fairing. As for the handle bars hitting the ignition cover I didn't do anything to mine and unless I am turning really sharp in the parking lot it doesn't hit and when it does it just moves it a little. Yes the only time it hitsis when bars are turned really tigh. That probably won't happen often. Could you send me a pic of your rubber text msg would be fine the number in my profile is my cell
Danaman Posted April 25, 2012 #6 Posted April 25, 2012 I took off the outer fairing and loosened the inner fairing slid the rubber mounts in and re tightened the inner fairing. This makes for a nice fit. Regarding the bars hitting the cover, I haven't done anything because it really doesn't do any damage. It pushes the cover in a bit but won't hurt it.
Dragonslayer Posted April 25, 2012 #7 Posted April 25, 2012 I've got one that came off a parts bike that is availlable. It is black but I think was originally burgundy and painted black with a rattle can. However, it does have a sticker on it that says WHO'S YOUR DADDY, is that a problem?
RedRider Posted April 25, 2012 #8 Posted April 25, 2012 I cut the corners off the rubber bumper so they would slip in. Much easier to do if you loosen the inner fairing. As for the ignition cover, I cut the corners off it too. Doesn't look the best, but since I hardly ever wash my bike, it doesn't show up. RR
pmj423 Posted April 25, 2012 Author #9 Posted April 25, 2012 AtlantaDragonslayer said: I've got one that came off a parts bike that is availlable. It is black but I think was originally burgundy and painted black with a rattle can. However, it does have a sticker on it that says WHO'S YOUR DADDY, is that a problem? sticker is not a problem. I have a friend that does custom leather work and was thinking of cutting it down and wrapping it with leather. I will PM you my info.
djh3 Posted April 25, 2012 #10 Posted April 25, 2012 Plastic cover is fine, no need to cut, bend, mutalate unless your trying to do something special. It will bend enough for tight turns. The rubber bumpers I lucked out and bought some milled dowels that bolt to the risers and go right in place of where the handle bars use to be. Still get a rattle every now and then on rough intersections etc. Check this out. Kirby a member here made them. http://www.venturerider.org/forum/attachment.php?attachmentid=51526&d=1287703597
