bags529 Posted April 24, 2012 #1 Posted April 24, 2012 I read.through a good bit, let me tell you what is going on. 84 VR Brake pedal bottoms out no pressure, had it earlier on first ride. Fronts, po had not tightened the caliper hoses completely and I know I'm going to have to change contaminated pads and bleed. All this in the first 40 miles....... Any tips ect on the bleeding and the rear and front left are what I am most concerned about. Thanks, first post Sent from my ADR6400L using Tapatalk
tcoop Posted April 24, 2012 #2 Posted April 24, 2012 I had a hard time bleading the linked brakes (left front and rear controled by rear MC) untill I put speed bleaders on. It now takes about 5 min to refreash the fluid.
