The 86-93 Ventures have an offset rotor design.
I think you are going to be very limited in what is available other than OEM.
I have a complete rear brake set for an MKII. Rotor, caliper, master cylinder, brake arm & S.S. line available. All are in excellent shape.
Proportioning valve will need the internal valve from old valve put in it. It was removed due to this setup was delinked brakes. Master was rebuilt & calipers have new seals in them. Pads are kevlar organics, good shape.
$250 plus actual shipping costs.
Gary
I should have a used one you can have in good shape. Therte is a member in Caledonia who should be coming down here in the near future to pick up some things, maybe he can bring it across for you...
  • 1 month later...
Gary
Hey Gary,if you still have this brake set up available,I'm interested......
I put on a new rear tire today and my rear rotor is bent....:bang head:
