I am going to put in the bypass for the battery level sensor on my '83 VR. I notice that there is already a resistor in the line. It looks factory. Do I remove this resistor when I put the new one in or do I just add the additional resistor?
I didn't remove mine, left it in and wired it to the acc screw,, works just fine.
Just make a complete new wire with a new resister from the accessory screw to the connector. If you hook power straight up you will damage stuff.
You only need one correct resister.
Edited by KIC
  Wizard765 said:
The existing resistor worked for me. Just left it in and did not add anything. Hooked that up to the accessory screw and works like a charm.
It worked for me also with my 88VR and I wouldn't have know that without the advice from Marcarl and Wayne (Wizaed765).
I left the existing resistor in. Added a 2.2K resistor in series. More resistance here is a safe thing and it was easy enough to remove the original resistor if I still had a battery warning on the display. No need to stress the CMU.
It works great with both resistors.
  • 2 months later...
Just bought sealed gell filled battery with no place to put battery sensor. Per suggested above I hooked up the exsisting resistor to accessory terminal on fuse block. Battery warning off. Thanks guys.
Jeff
