raybear71 Posted April 16, 2012 #1 Posted April 16, 2012 I"ve done all my rainy weekend maintenance and also ordered a sylvania silverstar ultra bulb for my headlight. Just wondering if I should order a porcelain plug for it or will the original be ok. Thanks, Ray.
Keemez Posted April 16, 2012 #2 Posted April 16, 2012 What's the wattage on it? I melted my stock connector with an 80/100w bulb. Patched in a ceramic as a temporary measure and now I'm converting to HID (35w).
Keemez Posted April 16, 2012 #4 Posted April 16, 2012 55/60 is stock so you shouldn't need to go ceramic for that.
friesman Posted April 16, 2012 #5 Posted April 16, 2012 The stock connector has been in my 85 with the Silverstar for about 4 years now with no issues.
greg_in_london Posted April 16, 2012 #6 Posted April 16, 2012 And I melted the standard connector with a standard bulb. I had to bodge it up at the side of the road and kept it like that for years. Porcelain bulb holders ???? I didn't even know they were available.
Keemez Posted April 16, 2012 #7 Posted April 16, 2012 greg_in_london said: Porcelain bulb holders ???? I didn't even know they were available. Yep. http://www.ebay.com/sch/i.html?_from=R40&_trksid=p3984.m570.l1313&_nkw=ceramic+h4+connector&_sacat=See-All-Categories
lsutley Posted April 16, 2012 #8 Posted April 16, 2012 Keemez said: Yep. http://www.ebay.com/sch/i.html?_from=R40&_trksid=p3984.m570.l1313&_nkw=ceramic+h4+connector&_sacat=See-All-Categories I did not know that there might be an issue with the OEM socket, when using the higher wattage bulbs! I need to remove the light bucket, to realign the adjuster shoe with the adjustment rod, and will upgrade to the ceramic socket. May not need the change, but insurance is often cheaper than the accident. Thanks for the information!!!
