Still a newbie.....stupid question...the cassette door is stuck closed...not a bad thing as posted here but would like to access the aux jack...any easy fixes ..have tried wd40 spray...pushed the stupid thing every way...can this be accessed behind fairing to trip door loose
thanks les
A real long time ago that happened to me as well I think I had to
put a nylon/plastic type wedge on the right side ? and kind of force
it open. then after that it worked right. now It has been removed
for my gages. good luck and don't break it ! :shock3: :080402gudl_prv:
Jeff
you would have to remove the fairing and then remove the
radio amp behind the door to even get to that door.
If you look under the tech section on how to add gages
it will show you picture of how to do this.
