GolfVenture Posted April 7, 2012 #1 Posted April 7, 2012 Trying to install the Chrome Rad Grill on my 91 VR. How does the Chrome Side Rad cover with the reflector go on? Normally the OEM rad grill goes on 1st then the side rad with reflector cover next.
GolfVenture Posted April 7, 2012 Author #3 Posted April 7, 2012 Ya, that was what I was guessing, but I've decided to ask for there has been times when I did not ask and there was a better way. So it looks like that I need a spacer the width of the origional radiator tab, then the side cover goes on, then the Chrome Rad grill (with spacers if needed but I'm thinking not). And I also will need to get 4 screws a bit longer than the origionals.
bongobobny Posted April 7, 2012 #4 Posted April 7, 2012 Yes you need the spacers unless you want to crack those plastic side covers...
GolfVenture Posted April 9, 2012 Author #5 Posted April 9, 2012 Got it on. Sure hope there aren't much maintenance that requires the rad cover to come off. It a pia. But sure looks like a million dollars.
