Hi everyone.
Will a V-Max clutch plates fit a Second Gen. Venture. If so which model do I go for.
Problem is I am having problems sourcing clutch parts in the UK other than genuine Yamaha ones for my 1999 Second Gen.
But there are hundreds of sources for V-Max clutch plates and spring.
Your thoughts please.:backinmyday:
Best wishes.
Neil. Old Miner.
Hi everyone.
Best wishes.
Neil. Old Miner.
The friction plates and steel plates are the same on VMax 85-07. The RSV's use the same plates from 99-10.
The spring, pressure plate & clutch boss have the same PN's on the VMax's as the RSV's show.
Go to partshark.com and you can compare part #'s.
Gary
