Done a few things to the new girl the last few days , one carb #1 was leaking checked it out and the screw for draining the carb was loose so hopfully that will be ok, then i had leak in the radiater so dug into that the fan was rubbing somewhere back a time took the other one off my parts bike my1990 put that on so all is fine for now, then put new plugs in, cold up here with rain so all wait awhile to go for ride to check things out. Who has those washers for sale here for the carbs to get better gas milage ? my other bike is a 1993 same as the 90 even same color.Oh yes put two washer in the fan bolts to have more room, so that wont rub again so you guys with the 1st Gen fix that it will save you in the end. 73 Yooper
  • 3 weeks later...
Yes the milage is lot better the best so far is 45 1/2 that is driving no more than 63 and that is a chalenge for me. Started off today when i left it was 39 just at the line for going out, got down by Crystalfalls and it was 60 , just 50 miles south of here. warmer tomorrow so south we go. 73 Yooper
Talked to Fred. He shimmed the carbs and picked up 6 mfg better fuel economy. Said the bike has more pep also.
I put the shims in mine, milage went up 5 mpg but PEP went down. I suppose I'll have to race Fred again on his new machine to see which ones the fastest. I got um on the old one but not by much as Fred states.
I ordered a set of the nylon shims for both of mine last week. I hope it helps my mileage. My biggest problem right now with the 86 is the diaphragms are shot. That$ gonna hurt the wallet !
Well, Guys got good news with the new shimms from skydock got the best mpg ever today 48.5 and also ive been putting in my home brew sea foam about 4oz per tank, works for me. The home made price per 16oz bottle comes to $1,17 a CAN , that sure helps the pocket book. 73 Yoop
Good ride today 359 miles bad wind only 44.3 miles per hour, got home just before it really started getting cold one more day to ride rain and south winds coming in, now bike catch up . 73 Yoop
