edtheguy Posted March 28, 2012 #1 Posted March 28, 2012 Ok Guys, Looks like I'm running on 2 cylinders.Pulled both caps off left side and no difference in idle. Left side from riders point of view. Pulled battery and box out and can see coils and TCI unit. All the screws are aimed forward so I guess you need to pull the fairing. How difficult is that. Is there anyway to pull the coils and TCI without removing it? Noticed the coils are stacked in pairs towards front, doesn't look like you can get to any of them for testing, but maybe I'm wrong. Hope so. Thanks for any light you can shed on this. Also what are the cylinder numbers and locations?
GolfVenture Posted March 28, 2012 #2 Posted March 28, 2012 Try snipping the ends of the plug wires 1/8 to 1/4 of an inch on the plug end then screw the cap back on and test. If that does not work then snip the other end and test.
OrlinEngh Posted March 28, 2012 #3 Posted March 28, 2012 I had the same problem on my 84 I trimed the plug wires back a 1/4 of an inch and got fire back to the plugs.
bike nut Posted March 28, 2012 #4 Posted March 28, 2012 I had the same problem on my 84 I trimed the plug wires back a 1/4 of an inch and got fire back to the plugs. I will have to try that on my 83 Venture.I didnt know you could even do that.
edtheguy Posted March 30, 2012 Author #5 Posted March 30, 2012 Tried snipping the wire ends at the plug--no change after start up. Ohmed out the ignition coils--got 3.3 ,also pullled plug off the back of the TCI and checked ohms on the pickup coils-all check out good. Note:this may seem like a stupid question but I'm assuming because I'm looking for a fault on the left (2) cylinders , I'm checking components on the left side IE: TCI plug and coils. Anybody got any suggestions?
Trader Posted March 30, 2012 #6 Posted March 30, 2012 'fraid the only help I can be is the numbering of the cyl. When sitting on bike... Rear left #1 Front left #2 Rear Right #3 Front Right #4
Power Trippin Posted March 30, 2012 #7 Posted March 30, 2012 If you have not checked for spark, using a tool specifically designed to do that, I would suggest checking it. If you do not have that tool, chances are, someone close to you does. Or, your local auto store will sell it. It is not expensive, and it will rule out spark, or no spark. If you have spark, then it is either the spark plug or a fuel issue.
deanmay Posted April 2, 2012 #8 Posted April 2, 2012 Electrical resistance increases as air pressure goes up. That means that testing the spark in atmospheric conditions (as opposed to under compression in the cylinder) will require a much larger gap than your average spark plug gap. You can get these testers at most any auto supply store Dean
bongobobny Posted April 2, 2012 #9 Posted April 2, 2012 You may be having a problem with one of the wiring harness connectors like the one that sends the TCI output to the coils, etc...
bkuhr Posted April 2, 2012 #10 Posted April 2, 2012 Ohm out the plug caps, removable resistors internal the caps could be open. If so could try cleaning, but would recommend replacement of caps.
