ACE50 Posted March 23, 2012 #1 Posted March 23, 2012 On RSV and RSTD there is a switched aux power plug under the seat avaliable for use with small rubber plugs covering the pin holes. Does anyone know what pins to order to be able to use this? Dealer not sure what I'm talking about. Both of my bikes have it just sitting there.
ACE50 Posted March 23, 2012 Author #2 Posted March 23, 2012 XV1100SE said: Best to either ignore it and run your own wires (I installed a 6 fuse block) or cut off the connector and solder into it. Guess I'll do that. Wonder why Yamaha would put it there if you can't use it properly?
etcswjoe Posted March 23, 2012 #3 Posted March 23, 2012 I ran across the power outlet that it plugs into once and I want to say it was around $150 I will see if I can find it again.
etcswjoe Posted March 23, 2012 #4 Posted March 23, 2012 (edited) They got cheaper only $50 bucks now http://www.yamaha-motor.com/sport/accessories/acscitemdetail/5/429/1785/12892/all/1/6193/0/detail.aspx the ad says it is for a snowmobile but it is the same plug. I am going to look on Mouser to see if I can find the plug itself, if anyone has it they will. Edited March 23, 2012 by etcswjoe
playboy Posted March 23, 2012 #6 Posted March 23, 2012 V7Goose has a thread on using this plug and attaching to it try a search of his threads.
etcswjoe Posted March 23, 2012 #7 Posted March 23, 2012 (edited) Take a look at this one, I think it may be it http://www.corsa-technic.com/item.php?item_id=337&category_id=54 http://www.hellotrade.com/senz-group-wan-chai/pin-plug-male.html#22486334 Edited March 23, 2012 by etcswjoe
Freebird Posted March 23, 2012 #8 Posted March 23, 2012 Just cut the darn thing off and put whatever you want in its place. That's what I did.
Dave77459 Posted March 24, 2012 #9 Posted March 24, 2012 I actually used the white cord today. I kinda used V7Goose's "Easy way to use that White Power Plug by Battery" how-to. I used needle-nosed pliers to pulll the gray plugs out of the caps, then jammed in the wires of the reservoir cover switch I wanted to power. They were too big to tin (not that I can do that well, anyways). But they went in far enough that when I plugged it into the powered end, it works, and reliably. I used shrink tubing to keep them in place. Caveats: * I used a volt meter to determine positive and ground before I went crazy. * The Kuryakyn Accessory Switch comes with a crap ton of in-line fuses, so I wasn't too worried about a loose connection, not that I think it is. In short, it was a five minute puzzle and install (not including the tank removal and routing, ugh), and it was free. And it works really well. Go for it! Dave
