I was doing some spring maintenance this past weekend which included changing the spark plugs on my RSV. I took some photos of how I easily installed the spark plugs without worry of cross threading by using a plastic tube to start the threading and hand tightening. I know that I read this tip somewhere (probably here) but thought I would post a photo of it for those who may not know this trick. The handle at the top of tube is a nail punch which made it easy to turn the tube and when the plug was hand tight you could see it slip. Once hand tight simply pull tube off plug and torque to spec. As we all know a photo is worth a 1000 words - right? :080402gudl_prv:
Edited by Chinto
Could not get it to attach photos correctly
:rotf::rotf::clap2: glad I got to see it before it gets remove LMAO !!
not to worry, I saved it and will send you a copy (for a small fee of course) :rotfl:
