George, two more Questions. how does one go about draining the oil if the plug
is that high? also, how long before I need to change it out one day?
From looking at the oil I had on my tie-wrap it looked real clean like brand new.
Thanks,
Jeff
You have to crack the case ( rear plate ) which is a big PIA cause the rear end is mounted to the frame,,,, or suck it out with an oil sucker.....
I think it was mentioned while I was there at the factory once that somewhere between 100 to 150 K for the change.
when was the last time ya changed the rear end lube on your truck,,,,,,,,,,, :) :)
:think:Think I changed the rear diff oil in my 1949 chevy pick-up in 1981 :D
OK George. Gunna cap it UP and walk away! THANKS!
Jeff
George, here is what Jim had to say.. I still think it is the middle bike tubes tho..
my vent tube on the top of the diff has no pinches. if this is what he means.
and that is about right the 1-1/4 below the fill hole. so thats good. and if it is
still there after 3 years it has to be the other tubes.
Jeff, The diff oil should be about 1.25" below the fill hole, It looks like youmay have had a leak at one time, you may check the vent tube to see if itmay have a pinched place on it. I have seen this in the past. Jim GoochHannigan Motorsports
