Hi all, my question is why would my #1 cyl run cooler than the rest of the other cylinders? Had the carbs sycn., with the engine warmed up cyl #2,3,&4 runs about 185 to 200 degrees while #1 runs about 170. It idles ok, runs revs up ok. I have not done anything to the carbs. The cyl takes longer to warm up than the others. I have put new plugs and caps & sycn the carbs. Any suggestions or leave it be.
Could be running a bit richer than the other cylinders. But given the minimum variance, personally I wouldn't worry about it.
If it is running a bit richer, the only thing that will happen is you may have to change the plug more often due to fouling.
How is the compression in the cylinder compared to the others?
Sea-Foam!!:clap2: Sounds as if that cylinder ain't pulling its full load. Maybe because it ain't getting enough juice to do so.
Edited by Yammer Dan
