colmike Posted February 28, 2012 #1 Posted February 28, 2012 Here's an inexpensive tool I just found at Walmart and used to add lubricant to my RSV's rear shock. It's called The MixMizer produced by FloTool and designed to assist with mixing the proper ratio of oil with gasoline for two cycle engines. At my local Walmart it was stocked in the automotive department near the oil funnels. I found it the perfect device for adding lubricant to the rear shock. As Rick Butler describes in his very informative thread about the OEM rear shock, "Understanding Your RSV Rear Shock", http://www.venturerider.org/forum/showthread.php?t=2220, I removed the Schrader valve and used the syringe and the included 4 inch extension tube to inject two ounces of lubricant. It worked perfectly for this task without spilling a drop of fluid. Here's what to look for,
djh3 Posted February 29, 2012 #2 Posted February 29, 2012 Looks like it may work very well for measuring out sea foam of fuel additives also. Certainly better then the syringe I have been using.
