GregWass Posted February 28, 2012 #1 Posted February 28, 2012 My breather plug is seeping on my '89....I noticed in the shop manual this plug can be replaced.....anyone done this before? Can the plug be pulled out w/ a pair of pliers or the like, or is there some special tool required? Considering how tight it feels, I wonder if I can get it our w/o breaking off a part of the plug. Thanks in advance, Greg
MiCarl Posted February 28, 2012 #2 Posted February 28, 2012 It's just a vent. There is literally a cone with a hole in the side of it and a hat on top to keep water out. If it's weeping it isn't your problem. There is some problem with the final drive (too much oil?).
GregWass Posted February 28, 2012 Author #3 Posted February 28, 2012 Nope, the final drive oil is at the appropriate level. I just figured maybe these things wear over time. Getting hot, getting cold, usual wear & tear. Actually, seeping is a bit severe. More like misting, just around where the plug contacts the differential. It's noticeable when the dust & dirt collect in the oil. Other than that, my diff is pretty much oil tight. I'd just never had this happen with this bike, so I thought maybe something was amiss. So, my question, still remains...can these be popped out easily or is it a major pain to get them out? Thanks for your reply, Greg
MiCarl Posted February 28, 2012 #4 Posted February 28, 2012 They're pressed in. You can fight it out with pliers. Tap new one in with soft faced mallet.
Bubber Posted February 28, 2012 #5 Posted February 28, 2012 Better get the new one before you take the old one out. Is it even available? Sounds to me like it should be left alone. It doesn't sound like it is a problem and it is working.
KIC Posted February 29, 2012 #6 Posted February 29, 2012 I have an 89 and not sure what you are talking about. Could you post a picture of it so I can look at mine and understand what the info in this thread is about ? Thanks... ( at least to me )
Ozlander Posted February 29, 2012 #7 Posted February 29, 2012 I don't understand how replacing a vent that's doing its job is going to fix anything.
skydoc_17 Posted February 29, 2012 #8 Posted February 29, 2012 I would be more concerned with what gear oil you are using in that final drive! It is impossible to overfill the final drive on a First Gen. MKII Motorcycle. Some oil mist around the vent is normal. Anytime you have oil collecting around an opening, dirt and dust is not going to be to far behind. Yamaha makes a fine Hypoid gear oil, I use the BelRay Products. The final drive is vented so internal pressure doesn't force the gear oil out of the seals. Changing the vent is not going to stop the oil mist from exiting the final drive, after all, it is a "vent". Earl
Flyinfool Posted February 29, 2012 #9 Posted February 29, 2012 One other thought. Check the temp of the rear end after a good long run, maybe it is getting hotter than normal causing it to vent more than it would otherwise.
Yammer Dan Posted February 29, 2012 #10 Posted February 29, 2012 I too would just wipe it off a little more often. It is working. I would check the heat after a run. It could have some wear causing more heat.
Rosie1965 Posted February 29, 2012 #11 Posted February 29, 2012 If you are intent on buying a new vent Bike Bandit probably carries them. I don't know about the Yamaha but they are $7 for my Hondas. Like the others have said, new vent won't fix the issue you are having.
GregWass Posted February 29, 2012 Author #12 Posted February 29, 2012 Appreciate all the advice....the plug is still available, I have one on hand. The only reason, I'm replacing it is the original must've gotten hit by a rock or some other road hazard, as it has a big dent in it. Since I'd never noticed it misting before, & because of the dent, I assumed the hit it took may have compromised it's function, therefore, needed replacement. I'll break out the shop manual & see if I can post a pic of it for those interested. I'll do that later this evening, I'm at work now. Hope the internet police aren't monitoring my "non-business" related postings. Greg
