jrsain Posted February 25, 2012 #1 Posted February 25, 2012 2007 RSTD w/23k miles and factory warranty until October. Yes; a squeak at idle and fading away with engine rpm, or at least I don't hear it. I just changed oil a few miles before it manifested itself most of the time at an idle. I could occasionally hear it prior to the oil change but very minor in volume, yet now much louder and most of the time. I took it to the dealer and he couldn't identify it yet was willing to tear into it but was cautious about doing that without a clear idea what they were looking for. He asked about oil change and I replied it was just done within a few hundred miles and it was 10-40 Kendal 4 stroke Motorcycle oil. He suggested that I change it to 20-50 since we live in south Florida and it should perform well with it, we could see if the change has any effect on the noise. I read a thread that sounded similar to my noise with the best comment being a possible water pump bearing but 90% of the replies were rhetoric about the OP have hearing issues, so please just good positive comments. Thanks
RandyR Posted February 26, 2012 #2 Posted February 26, 2012 not sure what the problem is but 50wt oil is for air cooled engines, not water cooled like ours.
warmbiker Posted February 26, 2012 #3 Posted February 26, 2012 i used mobile 1 20/50 in my 1999 valkyrie for 10yrs, it was by far the best oil for that engine, never had a bit of trouble, i am now using it in my 2006 RSTD with great results, this is only my opinion, i love mobile 1, thanks guys, warmbiker,
RSTDdog Posted February 26, 2012 #4 Posted February 26, 2012 COnstant squeal like a belt slipping all the time or intermittent squeak , squeak , squeak that goes faster with rpm? So it got louder after the oil change? What oil were you running before this last change? Did you change the brand of filter? Is it worse when engine is cold or warm or doesn't matter? Does it do it idle in neutral only or also idle in gear with clutch pulled in or slow speed in gear- say parking lot speed? If the noise stays the same regardless of engine temp I doubt the type or weight of oil will have any affect. Try and put it in gear and see if squeak goes away when you let out clutch. Put your foot on the brake and load the engine and clutch a bit. Can you hear it more on one side of the engine than the other? Could be as simple as needing a carb sync. Sometimes if the carb sync is out they will make different noises at idle. RSTDDog
johnbroughman Posted March 2, 2012 #5 Posted March 2, 2012 make sure you are not using oi with anti-friction in it as it will mess up the clutches and eventiually cause them to have to be replaced. I have been using Rotella 15 - 40 in my RSV and it works great, no problems in over 2 yrs and it actually made the whine a little more bearable.
Rick Haywood Posted March 2, 2012 #6 Posted March 2, 2012 Mine makes that noise sometimes when I first start it. Not sure what it is but I set the idle up about 100 rpms more and it doesn't do it any more. Before I raised the idle it didn't do it all the time and would go away after a short warm up
pickinfred Posted March 2, 2012 #7 Posted March 2, 2012 My 07 has made the same squeak/chirp seems forever. I added some Macs 1300 (anti-corrosion & lubricant) to the cooling system..thinking maybe the noise was the water pump?.....but still squeaks. May just be a little bird tweeting about an encounter with a Hardley or 1st. Gen:confused24:
jrsain Posted March 15, 2012 Author #8 Posted March 15, 2012 Thanks guys, just an update on the noise, as mysteriously as it surfaced it has gone away. So I guess it is just another of the many noises that makes these bike so unique. Oh well I still get many complements on how good it looks.
playboy Posted March 15, 2012 #9 Posted March 15, 2012 Since your fishing I'll bite :stickpoke:It does look good but what kinda pipes are those very nice.
hunter 1500 Posted March 17, 2012 #10 Posted March 17, 2012 playboy said: Since your fishing I'll bite :stickpoke:It does look good but what kinda pipes are those very nice. They look like the stock pipes with the tips turned out.
M61A1MECH Posted March 17, 2012 #11 Posted March 17, 2012 Yep those are stock Tour Deluxe pipes with the removable / roatatable tips. I have seen them put on a Venture with stock pipes, but be advised that the Tour Deluxe mufflers have threaded inserts in the cones on the mufflers to accept the screws that hold the tips on. For the Venture mufflers you would need to use some short stout stainless steel sheet metal screws to ensure they stay there and do not rust out.
