I took my Roadstar lights when I bought my venture, the bulbs are 55 watts, are they drawing too much power? or are the the right wattage for the Venture?
I'm thinking of going to a lower wattage bulb, because of all the lights I have on the back of the bike, and for the extra lights I have on the trailer. (4 3 candle watt bulbs as runners) & the LED run, brake, & turn on the back.
How many watts am I pulling when I'm running the radio, 3 head lights, and pulling the trailer? and what is the Max out put on the system?
  • 2 months later...
Depending on how they are wired in you could be over working the saystem. My RSV had the "fatory" wiring for the passing lights. When I went to install a realy as suggested I found the fuse holder melted. My lights were 35w. LED help with the draw but are expensive to say the least for the good ones. What size wire is going to be a major player as to how big of bulb you can run.
