wfdyer1 Posted February 20, 2012 #1 Posted February 20, 2012 Anyone have a surefire way to repair a hairline crack in a 28mm carb??Bought this 99RS and discovered a hairline crack at the base of the #3 carb where it goes into the intake.Sucking air and backfiring.
Marcarl Posted February 20, 2012 #2 Posted February 20, 2012 Could use a picture, but in the meantime, take the carb off, clean out the crack with a Dremmel tool, drill a very small hole at the end of the crack and seal it back up with JP Weld. The small hole will stop the crack from going any further, JP Weld will not. That's if the crack has nothing to do with any internal components. If you have to deal with internal components, you're in for another carb, I would think.
Flyinfool Posted February 20, 2012 #4 Posted February 20, 2012 Marcarl said: Could use a picture, but in the meantime, take the carb off, clean out the crack with a Dremmel tool, drill a very small hole at the end of the crack and seal it back up with JP Weld. The small hole will stop the crack from going any further, JP Weld will not. That's if the crack has nothing to do with any internal components. If you have to deal with internal components, you're in for another carb, I would think. :sign yeah that::sign yeah that:
djh3 Posted February 20, 2012 #5 Posted February 20, 2012 Yup JB should work. There use to be some other stuff called liquid steel and also liquid alum. Both will do the samething as the JB. Drilling the end of the crack should elminate the crack progressing. Of course clean it all off good. You might want to take the dremel and run the cutter blad thing along the crack and then some sanding to ruff it up so the JB gets a better grip. But probably not required.
DarkLeftArm Posted February 20, 2012 #6 Posted February 20, 2012 most importantly, after the repair is made, look for WHY it cracked in the first place. That just aint right.
Yammer Dan Posted February 20, 2012 #7 Posted February 20, 2012 JB Weld works great. Sometimes.... Drill it and make sure you get it in the crack good.
twigg Posted February 20, 2012 #8 Posted February 20, 2012 You also need to factor in "the law of diminishing returns". Remove-Repair-Replace is great, until the repair fails and you have to remove them all again ... and it failed in the middle of Nevada, at 2am ... in the rain. The suggestions are great, and may indeed work permanently, but first get a price for a decent second hand carb body.
wfdyer1 Posted February 21, 2012 Author #9 Posted February 21, 2012 Any ideas on where to find a used carb body??
Marcarl Posted February 21, 2012 #10 Posted February 21, 2012 twigg said: You also need to factor in "the law of diminishing returns". Remove-Repair-Replace is great, until the repair fails and you have to remove them all again ... and it failed in the middle of Nevada, at 2am ... in the rain. The suggestions are great, and may indeed work permanently, but first get a price for a decent second hand carb body. Nice thing about our bikes is that often times we don't even know that they are running on 3 cylinders, so if it does go again, you can still get home!
twigg Posted February 21, 2012 #11 Posted February 21, 2012 wfdyer1 said: Any ideas on where to find a used carb body?? Ebay or a motorcycle dismantler would be favourites. Yes, you can ride them quite comfortably on three cylinders. Often the only visible signs are a slight reduction in power and a large increase in gas consumption. You might not want to ride it too far with gas leaking around the hot bits. just sayin'
a1bummer Posted March 30, 2012 #12 Posted March 30, 2012 twigg said: You also need to factor in "the law of diminishing returns". Remove-Repair-Replace is great, until the repair fails and you have to remove them all again ... and it failed in the middle of Nevada, at 2am ... in the rain. The suggestions are great, and may indeed work permanently, but first get a price for a decent second hand carb body. What this guy said for sure. Years ago when I had my garage, I would tell my customers similar when they wanted something done on the cheap or wanted to use a junkyard part. I think it was "Ya can pay me now, or ya can pay me later". The right thing to do is to replace the cracked body. The best way to "fix" it would be to take it to someone who can weld it up for ya. It really won't cost that much. I would also be asking myself why it cracked in the first place. Like someone else here had already mentioned. JMTCW, Bill
