warriorhoneybee Posted February 20, 2012 Share #1 Posted February 20, 2012 i did a search and guess i'm more challanged than i thought. the search thing dosen't like me or something cause i don't get good results, and yes i tried modifieing my search.done some research lately and found that i need two if not three different air gauges.i based that on the theroy of getting a gauge that is in half of the zone. Ie the forks max p.s.i. is 7lbs so 0-15 would be correct,tires avon rear max 50 p.s.i so 0-100 would be correct.i guess the rear shock would be the same as the rear tire,my question is why would i need two different progressive air pumps(0-15& 0-60) when the 0-60 would work on both ? since i'll be useing two separate gauges.the pumps coast around 42-47 dollars and the gauges coast 14-21 dollars.my finial and guess real question is,could i not use a bicycle pump(small tube style that goes on frame)to work on the forks and shock? sorry for the drawn out gibbresh. Link to comment Share on other sites More sharing options...
Kirby Posted February 20, 2012 Share #2 Posted February 20, 2012 (edited) I think this is what you are looking for. http://venturerider.org/forum/attachment.php?attachmentid=54140&d=1298196431 You're looking for a "zero loss" air pump for the front forks and rear shock. Any tire gage will work for the tires. The forks require so little volume that it's hard to get just the right amount without loosing pressure just checking. The zero loss pump does just that. Never try to fill the front forks with a regular air compressor. You'll blow the seals. My understanding is Harley sells a good one but you can find them probably on Ebay also. http://www.ebay.com/itm/PROGRESSIVE-AIR-PUMP-W-GAUGE-0-30-PSI-UNIVERSAL-/390386684643?pt=Motorcycles_Parts_Accessories&vxp=mtr&hash=item5ae4dc12e3 Edited February 20, 2012 by Kirby Link to comment Share on other sites More sharing options...
Mike G in SC Posted February 20, 2012 Share #3 Posted February 20, 2012 Keep it simple. Go down to the Harley dealer, parts counter. Buy the pump they have. (Looks like the one Kirby has in the first link.) Use it as both guage and pump for front and rear shocks. Use a different guage and pump for tires. Mike G Link to comment Share on other sites More sharing options...
TDunc Posted February 20, 2012 Share #4 Posted February 20, 2012 Couldn't be said better. I finally did just that. Darn I thought it was just something else to spend money on but it was the best way to go to handle the forks and shock. I keep it in the bike all the time. Link to comment Share on other sites More sharing options...
M61A1MECH Posted February 20, 2012 Share #5 Posted February 20, 2012 Go to your local dealer and ask them to find the page in their Tucker Rockey parts catalog under tools in the suspension system section with these part numbers 07-0605, 07-0661, 07-0660, 07-0662 those are the pumps from Progressive they range fro 0-30 psi to 0-100 psi, pick the one(s) that suit your needs. Should be in the $35.00 to $40.00 range from a reputable dealer. This link should take right to a copy of the page. http://www.powersportrider.com/cgi-bin/zcatjpg Link to comment Share on other sites More sharing options...
warriorhoneybee Posted February 20, 2012 Author Share #6 Posted February 20, 2012 thanks for all the info. sorry about my long post,i read it this morning and thought what a idiot, must have stayed up to late. i will be getting the zero loss chuck. i had trouble finding them but now i hope i can get it. Link to comment Share on other sites More sharing options...
Rick Haywood Posted February 20, 2012 Share #7 Posted February 20, 2012 Order one from the dealer, about $45 but you will be happy with it and do not use anything but that small hand pump to fill the air assist shocks. Link to comment Share on other sites More sharing options...
warriorhoneybee Posted February 20, 2012 Author Share #8 Posted February 20, 2012 thanks rick Link to comment Share on other sites More sharing options...
warriorhoneybee Posted February 20, 2012 Author Share #9 Posted February 20, 2012 (edited) i guess i'm a damn idiot!!!!! i've googled zero loss air gauge and or pumps and all i come up with is the progressive air pump/slash harley air pump.i thought i saw V7goose post that they made a zero loss air gauge.someone please break out the crayons and help!!! thanks Edited February 20, 2012 by warrior/honeybee Link to comment Share on other sites More sharing options...
Rick Haywood Posted February 20, 2012 Share #10 Posted February 20, 2012 Mark, Here is what you are looking for. I ordered mine from Yamaha. Do not know if there is any difference http://www.ebay.com/itm/Air-Shock-Pump-Harley-Touring-Road-King-Street-Glide-/290339057837?pt=Motorcycles_Parts_Accessories&vxp=mtr&hash=item43998e70ad Link to comment Share on other sites More sharing options...
warriorhoneybee Posted February 20, 2012 Author Share #11 Posted February 20, 2012 thanks again rick,i found that i just thought they made a zero loss air gauge by it self. Link to comment Share on other sites More sharing options...
M61A1MECH Posted February 21, 2012 Share #12 Posted February 21, 2012 (edited) There is a pump for sale over on Delphi, see the link. http://forums.delphiforums.com/n/mb/message.asp?webtag=vrider&msg=12602.1 Edited February 21, 2012 by M61A1MECH change link Link to comment Share on other sites More sharing options...
warriorhoneybee Posted February 21, 2012 Author Share #13 Posted February 21, 2012 thanks for the info Link to comment Share on other sites More sharing options...
Yammer Dan Posted February 21, 2012 Share #14 Posted February 21, 2012 On the 1st Gen you push a button to adjust the front forks and the rear shock!!! Still gotta add air to the tires!! I don't know what was wrong with them!! Link to comment Share on other sites More sharing options...
warriorhoneybee Posted February 21, 2012 Author Share #15 Posted February 21, 2012 your killing me yammer dan. Link to comment Share on other sites More sharing options...
