I'm replacing rear tire on my 86 venture. That is going smoothly, however, I also want to replace the front tire as well and this is where I've run into a big fat... "HUH????". The front tire is a Bridgestone Spitfire touring and the only size I can see on it is listed as such: **** MR90-18 71H ***** again... HUH?????? what the heck is that? I've looked online and cant seem to find any such size. I'm Planning on going with the D404 Dunlop 140/90/16 on the rear from motorcycle superstore online as the $105 with free shipping seems to be the cheapest I can find. I'd like to put the matching Dubnlop on the front but am lost with this tire size issue.
Any help would be appreciated.
Thanks,
Jay
If the front wheel is standard then the tire size is 130/90 R18
That's a standard size and you should have a good choice of tires.
Mine has Bridgestone Spitfire IIs, F and R.
They are well priced, give decent grip and are moderately hard, so wear rate is good. I have never had cause to look much beyond them.
The manual for the VR calls out for a 120/90-18-65H.
I have a Dunlop Elite III MR90-18-71H on my Beast :detective:
MR90-18-71H
vs
120/90-18-65H
MR = 120 = 4.25 - 4.50" wide
90 = aspect ratio
18" diameter
load rating = 65 is 639lbs and 71 is 761lbs
H = speed rating
I found these charts when looking for tires . . .
Motorcycle Tire Speed Ratings, Load Ratings and Motorcycle Tire Size Designations
Front Tires
Rear Tires
metric
alpha
inch
metric
alpha
inch
80/90
MH90
2.50/2.75
110/90
MP85
4.00/4.75
90/90
MJ90
2.75/3.00
120/90
MR90
4.50/4.75
100/90
MM90
3.25/3.50
130/80
5.00/5.10
120/80
4.25/4.50
140/80
5.50/6.00
120/90
MR90
4.25/4.50
140/90
MU90
5.50/6.00
130/90
MT90
5.00/5.10
150/80
MV85
6.00/6.25
150/90
MV85
6.00/6.25
TIRE Speed Rating Chart
Maximum Design/Test Speed
J Type
62
100
N Type
87
140
P Type
94
150
S Type
112
180
H Type
130
210
V Type
149
240
Z Type
149+
240+
Tires with 2.00, 2.25 & 2.50 nominal section widths are rated for 75 mph.
LOAD INDEX (LI) RATING CHART
LI
lbs.
LI
lbs.
LI
lbs.
LI
lbs.
LI
lbs.
20
176
33
254
46
375
59
536
72
783
21
182
34
260
47
386
60
551
73
805
22
187
35
267
48
397
61
567
74
827
23
193
36
276
49
408
62
584
75
853
24
198
37
282
50
419
63
600
76
882
25
204
38
291
51
430
64
617
77
908
26
209
39
300
52
441
65
639
78
937
27
215
40
309
53
454
66
661
79
963
28
220
41
320
54
467
67
677
80
992
29
227
42
331
55
481
68
694
81
1019
30
234
43
342
56
494
69
716
82
1047
31
240
44
353
57
507
70
736
83
1074
32
247
45
364
58
520
71
761
84
1102
No. Standard tire is 120/90H18, which is a bias ply tire. The 130/90 R18 is oversize and radial construction.
As the chart shared by GaryZ shows 120/90H18 is the metric designation for the alpha MR90H18.
Heh ... I stand corrected, I wrote it down wrong and the tyre you just specified is exactly what is on the front of my bike. I just went and looked.
