:fingers-crossed-emoHi guys
I'm a newbee with a problem I need help with. I bought a 97 RSTD with 26000mi that was sitting up for two years. It starts but runs real ruff(suprise) I want to rebuild the carbs and since I'm adding aftermarket exhaust I want to re-jet. I was told I need to change the orings because of the ethenol in fuel these days,
1. Where is the best place to buy the rebuild kit?
2. What size jets do I need?
3. Is that true about the orings and if so will the orings in the kit do? If not where can I buy the orings?
Also this bike pulls left hard at very slow speed. I know that all bikes have their quirks but, Is this normal? Any other suggestions will be appreciated
Thanks for any help.
John
I'd run a couple tanks of gas heavily treated with Seafoam or maybe Techron concentrate or BG44, before tearing into the carbs. let it set a few hours in the carbs and ride it again.
  • 2 weeks later...
Not sure about rejetting until you get the exhaust on,see how it does.
As for the pulling,maybe a sticking left front caliper??I'd definitely swap out the brake fluid and get the calipers working right...I did the same as you,that is bought a 98 RSTD that was sitting and I drained all brake fluids,moved the caliper pucks in and out with a c clamp and put fresh fluid in.Good advise using sea foam or other fuel additives,try that 1st. Good Luck
i did exaclty what Randy recomended and it work like a charm, go for the sea foam, great stuff, warmbiker,:confused24:
