Yeah, Me To Doing the Stator Up-Grade LOL Yippy, and side reflector up-grade (top secret)
and Mud flap !! :happy65:
Id like to know more of the side reflector upgrade and mud flap. Time to get up and giter done see you guys in a few hours
I will try and take a few pics today of my lighted Side reflector Install for you.
Got them from JP Cycles about 2 years ago and just getting around to installing them LOL
I also just ordered the mud flap from CC and it just came in.
I did the Barnett pressure plate upgrade a few years ago and I got 75,000 worry free miles on it so far... It pulls a little harder than before but I don't notice it til I ride a stock RS... I've been using Barnetts since the 70s and have never had a failure...
Just some additional
:2cents: here, when you go to change out the spring and or the rear friction disc with a full sized one. Make sure that you scuff up the steels before reinstall them. This will remove any glazing that might have occurred if your clutch was slipping. I have done dozens of clutch upgrades, PCW, Skydoc's, and the cheap method of doubling up 2 stock springs. I have done all 3 methods on Ventures I have owned, and they all work great, it's all about how much money you want to throw at it.
good luck cougar,let me know how the stator works out. i would like to do mine in the near future,seems like i read a post somewhere on which one to get,also thinking i need to change out my rear shock. it seems to keep leaking down,any help on this matter would be helpful to. thanks
thanks cougar. hey squidley,besides the money differance,which of the three did perform the best?if you want to pm with the info you can. i'd like to save money however to me the performance is the bottom line,well with in reason i guess.
Hey squidley,besides the money differance,which of the three did perform the best? if you want to pm with the info you can. i'd like to save money however to me the performance is the bottom line,well with in reason i guess.
Mark,
Budget wise, doubling the stock diaphragm spring and replacing the back half friction disc with a full one is probably the cheapest route. You would need to have the cover gasket on hand too in case the old one doesn't come off in 1 piece. This also was the one that really locked the plates up and worked very well, only drawback is your left hand WILL get a workout. The clutch handle pull is noticeably harder and in stop and go traffic you might be cursing under your breath.
The PCW route will run you just under $100 shipped and comes with a new gasket, full friction disc for the back, and new thicker diaphragm spring, it's plug and play all the way.
Skydock's kit is the same way and is a bit cheaper in price. If you want to go the budget route PM me as I believe I have an extra stock spring, as well as a full friction disc I can get to you.
I just put Skydoc's kit in. It is working smoothly on my 09 RSV. I did the clutch spring and friction disk only. All of it is working great.
Thanks Skydoc I really appreciate your help.
Hal :cool10::cool10:
I just completed mine. Just thh upgrade full friction disk and upgraded spring. All went along smoothly.
The only thing i was concerned with i saw some blueing on the steel disks and I know I didnt slip but a hand full of times unless there was more slipping that I didnt notince. It wasnt bad so i scuffed them up and reinstalled.
http://i257.photobucket.com/albums/hh221/muaymendez/2012-02-19115609.jpg
http://i257.photobucket.com/albums/hh221/muaymendez/2012-02-19115508.jpg
http://i257.photobucket.com/albums/hh221/muaymendez/2012-02-19115456.jpg
I also have a set of barely used brake pads I will let go real cheap.
Thanks Skydoc for mentioning the pads. Im glad i purchased them. if anyone is thinking about thier brakes this one change increased my stopping power. I didnt realize that using a cheaper brake pad could make your stopping power suffer.
Ok whos interested in the pads.?
I bought the bike with these installed. The frints were not as bad but the way the brake feels now I think i had inferior pads.
http://i257.photobucket.com/albums/hh221/muaymendez/1329683900872.jpg
http://i257.photobucket.com/albums/hh221/muaymendez/1329683921063.jpg
I'm leaving tomorrow for work in Daytona for a week. Flanning on running backroads up about 160 miles. Suposed to be in the low 60's. Perfect. :cool10:
Quick update here.I think I know my last 3 steel plates had bluing on them.I found out tonight on the way home when I down shifted like usual abd the rear end broke loose skidding until I pulled the clutch.
I guess I have been slipping more than I thought.Not to mention it feels like I have way more power.A result of no slip.
